Mowing Overheats While Mowing
/ Overheats While Mowing #1
jwelsh86
Montgomery, TX
None
I am helping a friend who has identified her tractor as a TYM LT600 (not sure of model). She mowes mowes a couple of passes of a 10-acre tract and the tractor will indicate overheating. Fluids are good, no leaks, etc. Any ideas? Thanks.
/ Overheats While Mowing #2
Have you clean the radiator and screen in front of the rad out really good.
/ Overheats While Mowing #3
As ozley said, there is a screen in front of the radiator that gets clogged easily when mowing. I clean mine 2X day when mowing my trails. Easy way to clean is use a leaf blower from the engine side and blow thru the radiator and screen....works for me (should mention the engine is OFF while doing this:)
New Three Point Hitch Trailer Mover (A65579)
New Three Point...
2019 Nissan Kicks Hatchback (A66738)
2019 Nissan Kicks...
D8 CAT U-Blade (A68134)
D8 CAT U-Blade...
2007 FRAC TANK 500BBL WHEELED (A68842)
2007 FRAC TANK...
PORTA POTTY (A67714)
DAYTON 110,000 BTU OIL FIRED HEATER (A64276)
DAYTON 110,000 BTU...
