Overheating or What?
/ Overheating or What? #1
bc realtor
Vancouver Island BC
Antonio Carrero TTR4400
I have the Antonio Carrero ttr4400 with the yanmar 3cld engine. have an issue with the thermostat I thought yet now I have the thermostat replaces and the engine is going into the red again.:mad:. I have used my temp sensor on the thermostat area and it reads 10 degrees below the temp marked on the tthemostat.
Am I missing something or what?
Just to let yoou know, it takes about 5 minutes for it to go from the green zone to the red zone on the temp guage.
I also can operate the tractor without the thermostat and it hovers just below the hot range but stays in the green?:confused2:
Do I just throw out the thermostat and go back to working the tractor without it?:anyone:
This is getting fun now. There happens to be two sending units , one below the thermostat and one above. I moved the sensor wire from the one below to the one above and went mowing for a few minutes. then I heard an autable alarm sounding but the temp was in the green. I switched the sensor back to the lower unit and it stopped the alarm but seemed to be in the green for temp range:confused2:
is there any way to test the temp sensor? I have tried the laser digital thermometer on the housing and it seems to be measuring about 8 degrees below the themostat temp.:anyone:
/ Overheating or What? #7
You can test them, if you know what the OHM's reading are at different temps. There a thermistor, the warmer they get, I the lower or higher the resistance reading you'll get from it. trying to find the spec's for one is the problem.
PS I would run the engine without a thermostat for very long. On some engines, running without a t-stat will allow the coolant to circulate to fast an cause an overheat problem
2013 Komatsu WA320 Wheel Loader (A60352)
2013 Komatsu WA320...
2006 Hummer H3 4X4 SUV (A61574)
2006 Hummer H3 4X4...
2018 HINO 338 KNUCKLE BOOM TRUCK (A63276)
2018 HINO 338...
2014 Volvo Sleeper Tractor (A62679)
2014 Volvo Sleeper...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A60460)
2019 Ford F-150...
2023 Kubota SVL97-2 Compact Track Loader (A63689)
2023 Kubota...
