Overheating or What?
/ Overheating or What? #1
bc realtor
Vancouver Island BC
Antonio Carrero TTR4400
I have the Antonio Carrero ttr4400 with the yanmar 3cld engine. have an issue with the thermostat I thought yet now I have the thermostat replaces and the engine is going into the red again.:mad:. I have used my temp sensor on the thermostat area and it reads 10 degrees below the temp marked on the tthemostat.
Am I missing something or what?
Just to let yoou know, it takes about 5 minutes for it to go from the green zone to the red zone on the temp guage.
I also can operate the tractor without the thermostat and it hovers just below the hot range but stays in the green?:confused2:
Do I just throw out the thermostat and go back to working the tractor without it?:anyone:
This is getting fun now. There happens to be two sending units , one below the thermostat and one above. I moved the sensor wire from the one below to the one above and went mowing for a few minutes. then I heard an autable alarm sounding but the temp was in the green. I switched the sensor back to the lower unit and it stopped the alarm but seemed to be in the green for temp range:confused2:
is there any way to test the temp sensor? I have tried the laser digital thermometer on the housing and it seems to be measuring about 8 degrees below the themostat temp.:anyone:
/ Overheating or What? #7
You can test them, if you know what the OHM's reading are at different temps. There a thermistor, the warmer they get, I the lower or higher the resistance reading you'll get from it. trying to find the spec's for one is the problem.
PS I would run the engine without a thermostat for very long. On some engines, running without a t-stat will allow the coolant to circulate to fast an cause an overheat problem
2023 Posi Track RT25 Compact Track Loader Skid Steer (A61572)
2023 Posi Track...
JOHN DEERE 5403 TRACTOR (A62130)
JOHN DEERE 5403...
2020 Ford F-150 4x4 Crew Cab Pickup Truck (A61573)
2020 Ford F-150...
8' DISC HARROW (A60430)
8' DISC HARROW...
2018 Kia Forte Sedan (A61569)
2018 Kia Forte...
Rake Master CR-72G (A64119)
Rake Master CR-72G...
