Overheat on first cold day
   / Overheat on first cold day #1
Gadgetnut
San Juan Islands, Washington
Walker Mower MD (Kubota,) BobCat ToolCat 5600 Turbo rev. C, John Deere tractor
We had a cold snap for us, 28 degrees. This morning my helper had been using the ToolCat for light duty use (no hydraulic tool, just driving around the property) for 45 minutes. With no warning, he hadn't noticed the temperature gauge rising, a warning light came on the dash and he saw smoke and turned off ToolCat. Lots of smoke, looks like most of the antifreeze boiled out. I followed a trail of leaking antifreeze a few hundred feet. We're going to let it cool. We'll look for a missing belt, a hose failure, the radiator cap, see if the fan comes on... what else should we look for? Overheating under light duty on such a cold day? Thanks. -Gadgetnut
Followup. After it cooled we started machine no problem. Raised the bed and examined the engine. Belts seem to be fine, the coolant reservoir cap was tight and made a light vacuum sound as we released it. The coolant reservoir is completely empty. No sign of broken hose. The fan blade is unobstructed-- spins freely at rest. We put some coolant in it and drove it up to the shop and parked it-- seemed to run fine.
Any input as to why we would experience a sudden overheat like this?
Next step, I was going to start engine and let it run warm up to temperature and see if any coolant leaks are visible under pressure and if the fan ever cycles on.
   / Overheat on first cold day #3
Thermostat stuck shut? Is the cooling fan running when engine hot? I think you need to run it again under some load and watch the temp gauge and see if it repeats. Wild guess but may be cooling fan.
   / Overheat on first cold day #4
Can you tell where the coolant was leaking from? Engine block heater, freeze plug, etc...
DEWFPO
Hi Rad. Given I haven't yet found any disruptions or leaks in the coolant lines, the cooling fan not coming on seemed like a possible cause.
Hi DEWFPO. When it became known the coolant was boiling out we turned off the machine and couldn't raise the dump said to see what was happening. The coolant was dripping down directly underneath the coolant reservoir. I don't know where coolant is intended to discharge from in a boilover situation. After things had cooled off we refilled the coolant reservoir with maybe a half gallon of Bobcat antifreeze and it held-- no apparent leaks sitting or operating for 5 minutes.
Like I said, my next step might be to let the machine come up to operating temperature again and see if the cooling fan ever triggers on. Other?
   / Overheat on first cold day #6
I believe the cooling fan is hyd-powered. You might check the fluid level. I'd try to exactly re-create the failure mode.
BTW, it's supposed get down to +2 here tomorrow AM.
Spud, you mean check the fluid level to make sure the cooling fan has hydraulic flow? Yes the cooling fan is definitely hydraulic, I was thinking there is an electric thermostat somewhere that sends a message, start the fan. Over the next few days I'll try to re-create what happened today, which was quite strange. BTW, Spud, I lived in Idaho for twelve years, so I know. Pretty funny but I was thinking of you when I started this thread earlier... my first words were, "We had a cold snap for us, 28 degrees..."
   / Overheat on first cold day #8
Yes, just the hyd fluid level. Might as well knock-off the easy stuff first. From looking at the service manual (for the "D"), it appears that the fan controller can throw codes (35-xx). You might check that as well. Looking at the wiring schematics it appears that the temp. sensor is an input into one of the controllers and there's a controller output that controls the fan solenoid. Not much help...sorry.
   / Overheat on first cold day #9
the key point is if your fan is turning on or not. if not that really narrows the potential culprits. if it is running and the radiator is clear then things may be more complicated.
ts
   / Overheat on first cold day #10
Gadgetnut, Did you ever figure out what was wrong? DEWFPO
Pallet Of Mini Excavator Attachments (A47384)
Pallet Of Mini...
2004 VERMEER BC1000 BRUSH CHIPPER (A50854)
2004 VERMEER...
1273 (A50490)
1273 (A50490)
2013 John Deere 35D Mini Excavator (A49461)
2013 John Deere...
2011 Ford F-250 Omaha Service Truck (A50323)
2011 Ford F-250...
100 GAL FUEL TANK (A50854)
100 GAL FUEL TANK...
