Over tightened Cap Screw!
   / Over tightened Cap Screw!
Is there any difference between Helicoil and TimeSerts? Does one perform better then the other in aluminum? Ease of installation?
Thanks again.
   / Over tightened Cap Screw! #22
Thanks again.
They are the same but different. Either will work for you. Just try to find a "kit" that includes the drill bit as it will be an odd size needed because of the metric thread. Again I think you should do both at the same time while it is apart.
Once try the thread repair insert's, you will be amazed how easy they are to use.
   / Over tightened Cap Screw! #23
i would just tap it next size bigger mite have to drill a little out .
   / Over tightened Cap Screw! #24
I over tightened one the cap screws (D) when changing the transmission fluid. I removed the
Suction screen cleaned and reinstalled. I have since lost the cap screw, it must have vibrated off. Is there an inexpensive repair that I can tackle my self or is this a dealer issue? Any help will be appreciated.
MX12150, MX12314
5. After oil is drained, remove two cap screws (D), two lock washers (E) and suction screen cover (F).
That is what Id do. A helicoil or Timesert/Casecert [stronger] will require drilling out too much parent metal. If you instead use a 3/8x16 american bolt it will work out perfectly. You would 1st drill the cover hole to 3/8 and bolt it back in stable position with the good bolt. At this point the through 3/8 hole should line up perfectly with the stripped hole [that, if stripped by an 8mm is perfectly sized for running a 3/8 tap into. The cover will guide you in straight. Since you dont have experience, use a good High Speed steel tap. These cost double, but are much stonger than the carbon steel variety so they wont break with out a major oops. Just be sure the guide/cover hole is concentric with the hole to be tapped, otherwise the tap will catch cyclicly in the guide hole as it turns.
If you were to go up one metric size it would be a bigger size increase than jumping over to the american coarse thread I named.
larry
   / Over tightened Cap Screw! #25
I disagree....Especially given the location...more then enough parent material..
While it will fix the problem for now, the repair is no different then the original setup...what you gonna do when the 3/8" bolt hole is stripped?
With a Helicoil repair, you end up with a STRONGER then factory repair. And you dont need to worry down the road when changing the oil & filter...Plus you keep it "factory".... Because this is an "often removed" piece a helicoil repair is that much better (Steel on Steel threads instead of Steel in Aluminum)
As an added bonus, you wont need 2 different sockets, wrenches, etc.. when changing the filter..plus what happens if you accidently wind the 3/8" bolt into the untouched/original hole? Looks like your doing another repair...
Without a doubt I'd "Helicoil" it....If I were in your shoes, I'd probably use a Recoil brand Keysert....
Keyserts are pretty much PERFECT for use in aluminum...and I like Keyserts because the external threads are "standard" in other words, no special drills or taps required.
Pretty Sure the PN# you need is 75081 - Internal thread is M8-1.25, External threaded M12-1.25, Length 12mm...
I'd use a 27/64 Drill bit to drill then tap it..
Double check my work...I dont want to be responsible for wrong numbers/etc...:D
Thanks Dave, I plan on going the Helicoil route, I looked into Keyserts but they are a harder to find. I appreciate your feed back.
   / Over tightened Cap Screw! #27
1]The 3/8 bolt cant get to the smaller thread and even if it did it wouldnt start to thread in.
2]The 3/8 bolt setup will be very strong because it will engage a lot more metal than the smaller original that was designed for the job but was stripped from overtightening.
3]The 3/8 Al thread wont strip if the op has learned his lesson. If he does strip it the resulting stripped hole would be 0.370" -- still requiring drillout to get up to the 0.422" holesize needed for the keysert.
larry
Update: I made the repair Saturday (Helicoil) and all went smoothly. Thanks you all for your input. I can't tell you how much I've come to rely on this board and it's members. Thank you.
   / Over tightened Cap Screw! #29
That is GREAT news! Did you do both holes?
Sure did, it just made sense.
2014 Ford F-150 Ext. Cab Pickup Truck (A55788)
2014 Ford F-150...
2005 Eager Beaver 20XPT (A47477)
2005 Eager Beaver...
2012 PETERBILT 388 DAYCAB (A53843)
2012 PETERBILT 388...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
UNUSED IRANCH IRMC HIGH END ELECTRIC MASSAGE CHAIR (A54757)
UNUSED IRANCH IRMC...
UNUSED RAYTREE RMT48 HYD TRENCHER (A54757)
UNUSED RAYTREE...
