rgr33
Platinum Member
- Joined
- Mar 21, 2012
- Messages
- 842
- Location
- Hillsboro or
- Tractor
- Kubota B2320 LS g3033. Kubota RTV 900. Exmark Lazer Z
I have worked with the kind of forks you are considering. They are not nearly as good as good as QA forks, but better than clamp on.
Pros and cons: easy to hook on, and take back off, but you need the hooks welded on your bucket
Can’t see the fork tips worth a darn when close to the ground, might not be a problem with logs though.
You lose lifting capability due to forks being out front so far.
The forks sometimes slide out of position on the bar if not secured well while traveling on rough or sloped ground.
Even with the issues listed, I still use mine all the time, as you can hook them up without ever leaving the seat, a big plus for me.
