Over running clutch wobble
   / Over running clutch wobble #1
Budman1950
SE La.
YM2210
My ORC on my 2210 has a distinct wobble to it when bush hogging. You can disconnect the PTO shaft and move the ORC around a good bit. It is the quick disconnect type and I was wondering if they have a rebuild kit for them? The non quick disconnect type seems to be more heavy duty then the quick disconnect type. All I use the PTO for is bush hogging so it won't have to be removed for any reason once it's installed. Thanks........Budman
   / Over running clutch wobble #2
I know what you mean. Mine (Quick Connect type) has a lot of slack in it too. I do keep it greased regular also- always have. I'm not gonna re-build mine. When it all flies apart, i'll put my spare one on there and when it eventually flies apart, then i'll buy a new one. But the new one will probably be the non-disconnect type.
Travis R
Hey Budman1950,
What part of Louisiana are you in. Who did you buy your tractor from?
I live in Thibodaux and have a camp South of Merryville. That's where the tractor is. Use it for bush hogging around the camp on the lease. Also preparing food plots.
I bought the tractor from South Circle in Alexandria. So far I've very pleased with it and nothing to complain about. It runs great and looks pretty good also. I just changed the oil and filter and the hydraulic/transmission oil.
   / Over running clutch wobble #4
In my opinion, the non disconnect type with the drive in pin is the way to go. I tried the drum one with the push button and it wobbles around to much just like you said.
Since I switched over to the pin type I have no wobble on the pto shaft , although it requires a little more grease than the other.
I also think they are built a little stronger. (US made)
happy mowing:D
Appreciate the help! I'm going to get the pin type and keep the other for a spare. Of course I'll have to see if I can take it apart and then it'll probably end up as a trot line weight or something, thanks again.........Budman
Frontier RT3042 (A50123)
Frontier RT3042...
2001 INTERNATIONAL 2574 6X4 DUMP TRUCK (A51406)
2001 INTERNATIONAL...
JOHN DEERE R4023 LOT NUMBER 152 (A53084)
JOHN DEERE R4023...
UNUSED HURRICANE D6028 JOB BOX (A51248)
UNUSED HURRICANE...
12" x 16.5" Kubota RTV-X1140 Tires (A52377)
12" x 16.5" Kubota...
2016 JLG 2032ES Electric Scissor Lift, 369hrs (A52384)
2016 JLG 2032ES...
