over -run clutch problem
   / over -run clutch problem #1
vincewine
waynesboro,georgia
yanmar 2000
I have got a clutch that I could ONLY get 1 grease zerk removed at this time. If i can't get the other out. Will it work just as well?
   / over -run clutch problem #2
One time, when trying to remove an overrunning clutch, I was able to get both zerks off but couldn't locate the pin because of all the hardened grease and debris inside. I simply compressed the C-clip holding the clutch together and slipped the outer housing off, exposing the inner components. After a little cleaning with a wire brush, the pin was obvious, and I could drive it out. Put a bucket under the clutch to collect the little parts as they drop out. Reassembly is no problem.
Frank Z.
   / over -run clutch problem #3
I've pumped grease into one of the zerks on an overrunning clutch with the second zerk removed and the grease came out the opening so my guess is you only need to put grease in one.
   / over -run clutch problem #4
Those grease zerts serve 2 purposes. 1) to get grease to the moving parts inside the clutch and 2) provide an opening so that the retaining roll pin can be inserted and removed. Either one will provide grease for the entire assembly.
Mike
   / over -run clutch problem #5
I only have 1 fitting on mine
   / over -run clutch problem #6
Kenmac,
Is yours the quick disconnect variety?
Mike
   / over -run clutch problem #7
MJPetersen said:
Kenmac,
Mike
yes, it is
   / over -run clutch problem #8
That is why it has only one grease nipple. The ones with 2 have the retaining roll pin. One grease fitting is all that is necessary, but they put two because they had to have 2 holes and they either had to put a plug in it and a grease nipple is cheaper!! (My guess)
Mike
   / over -run clutch problem #9
i have one of the non-quick disconnect type. I had to remove 1 nipple to install the roll pin Then put it back on. i have never had it off again. i agree that it is only there to cover the hole.
Bushhogged on friday and it works just fine with 1 . but it will be a problem if i have too take it off.
Engel 20' Boat (A50121)
Engel 20' Boat...
FORD F450 SUPER DUTY TRUCK (A51406)
FORD F450 SUPER...
COOPER LIGHTING CAT. NO. MHEP-22/28-175-MT (A53472)
COOPER LIGHTING...
2019 GENIE GTH-5519 TELESCOPIC FORKLIFT (A52706)
2019 GENIE...
2010 Lincoln MKS (A50324)
2010 Lincoln MKS...
