over-ride 1541 reverse/pto
   / over-ride 1541 reverse/pto #11
Don't you have the keyswitch override system? The switch is right behind the battery by the linkage; you may be able to reach it without removing battery, but removing battery is a quick job; loosen two bolts that hold switch ( microswitch with an arm on it that touches the shifter linkage) remove one bolt and let it slide so it does not make contact with linkage, tighten remaining bolt to hold it in place. Not recommended to do to defeat safety system; just to check the operation of the switch only :)
Dave
whoops!! finally a nice day yesterday. looked into this "pto" issue. as directed, i did find a small micro-switch bolted to back of dash panel. appeared to have a long arm as part of the switch. i noticed that it would be "made" with shift lever going into the reverse direction. somehow the arm got "bent" when i had my hand in there. now pto does not disengage when put into reverse. i will probably have to look into that later! THANKS EVERYONE!!!
   / over-ride 1541 reverse/pto #13
Glad your PTO situation has been solved.
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
2005 Volvo VNL Truck, VIN # 4V4N19TGX5N374968 (A57453)
2005 Volvo VNL...
2015 Freightliner Bucket Truck (A55973)
2015 Freightliner...
2023 RTVXG-850 SideKick (A56435)
2023 RTVXG-850...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
2015 FORD F-350 XL SUPER DUTY SERVICE TRUCK (A51406)
2015 FORD F-350 XL...
