Oil & Fuel over filled front axle oil
   / over filled front axle oil #1
vtcoyote
KIOTI CK 35 HST
I just finished the 50 hr. service:) and when I was filling the front axle I accidentally over filled it. The fluid is not coming out of the filler hole(s) but the fluid is above the gauge on the front axle.
I know that over filled hydralic oil is not preferable but is a over filled front axle going to cause damage?
more mistakes to follow:D:D:D
thanks
   / over filled front axle oil #2
Are you checking it when the machine is level? It makes a big difference.
If it were way over I'd just loosen a drain keep your fingers on it and let some out.
Mike
   / over filled front axle oil #3
Or you can go to an auto parts store and buy a gadget that will suck the excess fluid out, it works like a good size plunger, I have 2 and I use them well, I don't know the name of it but maybe someone will chime in with it
Jim
   / over filled front axle oil #4
try a turkey baster, agro supply stores also have large syringe's, attach a piece of windshield washer hose and suck some out,
   / over filled front axle oil #5
I would make sure it is too full after a little time. It seems like a takes some time for the oil to get past the differential into the other side. Because of this I under-filled mine at 50 hrs and did not check it properly afterward and had to replace parts inside. A couple lessons were learned the hard way.
   / over filled front axle oil #6
I replaced mine and when it looked full, it didn't take the entire amount as listed. I thought the capacity was a misprint. I drove it around my place for a few hundred yards and now it was low. There must be air pockets somewhere that give you the false reading on a refill. Just make sure you drive it around a bit and recheck. As previously mentioned, if still to full, just pick a side and drain a little.
   / over filled front axle oil #7
this same thing happend to me with my Dk 35
It does hold what it says in the man.
I jacked up the frontend and moved the tires and pivited the front end back and forth and got it after awile,make sure and check it like 3 or 4 times after you drive it you will get it right after awile
Goood luck
matt
UNUSED HURRICANE 7' X 12' CONTAINER (A51248)
UNUSED HURRICANE...
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
(3) 55-Gallon Drums of Fertilizer (A51573)
(3) 55-Gallon...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
2015 TAKEUCHI TB290 EXCAVATOR (A51246)
2015 TAKEUCHI...
2014 Dodge Charger Sedan (A51694)
2014 Dodge Charger...
