Outside Water Hydrant
/ Outside Water Hydrant
Thanks for the reply, Daily use is off and on several times
a day. I too have a clay soil and may have to dig a bigger
dry well. But my main problem is when it is off water still
leaks out of the drain hole, or the facet since I put a plug in the drain hole.
Will probably check around for a repair kit to see if I can find
one. Not holding my breath since our TSC is not that well
stocked.
Larry
/ Outside Water Hydrant #12
remember that it can take awhile for the water in the barrel to leak out since it isn't much more than a weep hole. Even with only a 2 foot hydrant, there's still a fair amount of water in the barrel when you shut it off.
Fortunately, if it is the seal, all the work is from the top.
You might want to check with the manufacturer for the seal kit, it should have lasted much longer (like years!) before seal damage occurred so they may just provide you the repair kit.
2021 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2021 KENWORTH T680...
SALTYS MANFUFACTURING 500BBL FRAC TANK (A58214)
SALTYS...
2019 Deere 35G (A53317)
2019 Deere 35G...
2025 JMR 36in Bucket Mini Skid Steer Attachment (A59228)
2025 JMR 36in...
2006 Dodge Ram Pickup (A56858)
2006 Dodge Ram...
2009 Case CX36B (A60462)
2009 Case CX36B...
