output shaft cover
   / output shaft cover #1
Ed Weber
Wilton, CA
MF 1635
Hopefully simple question
I have a 1635, I'm looking for a simple output shaft cover. The plastice cover it came with was bolted on. I'm looking for something to slide on and off easily without tooks.
So, my question is what do you use or where do you buy them.
Thanks
   / output shaft cover #2
I still use the bolt-on cover for my rear PTO (don't use it a lot), but for other output shafts --mid PTO, MMM,etc.-- I've been using lengths of 1" heater hose with a plastic spray-can cap super-glued on one end. Works well, and the slight curve in the hose holds them in place nicely. Your shafts may be larger than my SCUT's, but I bet you could find some rubber hose to match.
Clever, thanks
   / output shaft cover #4
Great idea Walt! We make some rubber hose that large and a couple pieces of end scrap would work perfectly.
Thanks,
Jeff
Sent from my iPhone using TractorByNet
   / output shaft cover #5
Glad to help! I've even left my rubber hose cover on the mid-PTO when it's vacant, still running the tractor; no problems, keeps dirt & stuff off the splined shafts. Same for MMM and other assorted shafts when in storage. For larger shafts (snowblower), I use a piece of round cardboard shipping tube for storing.
2020 JOHN DEERE CP690 LOT NUMBER 204 (A53084)
2020 JOHN DEERE...
Homemade 18ft x 6.5ft Gooseneck Trailer (A51572)
Homemade 18ft x...
LOAD OUT AND SHIPPING (A51572)
LOAD OUT AND...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
UNUSED CHERY INDUSTRIAL SINGLE GARAGE METAL SHED (A51248)
UNUSED CHERY...
2014 CATERPILLAR CT660S SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
