Outdoor Wood Boiler, what do you have, any problems with it?
   / Outdoor Wood Boiler, what do you have, any problems with it? #1
blucoondawg
Pelican Lake, WI
Kioti DK50SE w/ loader and Woods 90x backhoe, Allis Chalmers C with front snowplow
I am trying to gather some info on different brands of OWB's, I live in Northern Wisconsin and I know quite a few people with OWB's but they only seem to be a couple different models which are popular here, and I know many of them have had problems with the firebox rusting through and leaking. What brands/models do you folks burn, how long has the unit been in service, and have you had any problems such as rusting out or leaking? I am only looking for response from people with experience or who know someone who has had experience, I am not interested in opinions from people who are going to tell me wood stoves are bad for pollution, too much work, inefficient, dangerous, etc. I have dealt with cutting firewood my whole life, I believe in my circumstances it is much more economical than any fossil fuel heat.
I am currently running an add-on forced air woodstove in my basement with a propane furnace I use for backup, but am considering going to the outside burner next year for many reasons, mainly the wife claims her allergies are worse in the winter with the little bit of wood smoke in the house, and my masonry chimney is getting in rough shape and I don't really feel like building a new one, I'd rather get rid of the mess in the basement, also having the burner outside gives me a little added peace of mind knowing there is no danger of a chimney fire in the house.
So far I have seen Central, Johnson, Cadillac, and Aqua Therm around my area, I wouldn't touch a Johnson or a Cadillac with a 10 ft pole, these are very popular here as there is a local shop who built them, that shop went out of business and changed owners but I'm not sure if the quality of the product has improved. It seems Central and Aqua Therm have the best record from what I have seen for durability, though the Aqua Therm is a lower water capacity sealed system.
   / Outdoor Wood Boiler, what do you have, any problems with it? #2
I have an indoor wood boiler. It's the same idea but without the enclosure. It is what is called a gasification or "gasser". What that does in simple terms, is burn the wood and all the gasses that are created when the wood is heated up. These gasses are (very) basically the *creosote and some ash that usually are not burned with a regular wood burning device. I would recomend spending some time over at Hearth.com Forums Home and look at the "boiler room" section. Keep in mind that some over there are kinda OWB snobs, but I think that is from the reputation of the early "smoke dragons", and the folks that used them that burned everything from green wood to RR ties and tires in them. There are now OWB's that are "gassers" and they have come along way. I've read of several happy folks with a Portage & Main OWB.
Just remember to use well seasoned (dry) wood, at least c/s/s for one year, and I would recomend a gasser. When up to temp and running, there is NO visible smoke. And a pressurised unit as well. For the heck of it I'll give the link to my boiler. Keep doing your homework and good luck!
http://www.alternateheatingsystems.com/index.htm
* This is useable fuel and will greatly reduce your ammount of wood use.
   / Outdoor Wood Boiler, what do you have, any problems with it? #3
My neighbor has an OWB about 120 feet away from and 25 feet uphill from my house. Air drainage in calm conditions make it the single most obnoxious thing I have to put up with. Nothing more aggrivating than having to close up the house on a nice evening just because of the neighbor's heat source. He must use it to heat domestic hot water and maybe his pool because it is used year-around.
   / Outdoor Wood Boiler, what do you have, any problems with it? #4
Slightly off topic, but if your chimney is marginal have you thought about getting it relined? As I understand the process, a stainless steel flue is installed and the remaining space filled with high-temperature-resistant concrete. Sure beats building a new chimney.
Relining wouldn't do me a lot of good, my concrete blocks are getting cracked up on the outside rather badly, I am going to mix up a batch of mortar and go up there and patch it up best I can for this year but it will need a new chimney if I want to keep using it. I think the biggest problem is it goes up the outside of my house rather than through the inside and out the roof, I have been told having them completely outside like this is hard on them, I assume because of the drastic temp changes every time the fire goes out and is restarted.
If it causes you such problems why don't you call someone at your local zoning office, there is probably something that can be done about that, I know here there is no permit or anything needed to install a boiler but if a neighbor does what you are describing we can contact the county and the health department will come out and if it is a situation where the smoke is continually coming in your house they will do something about it.
   / Outdoor Wood Boiler, what do you have, any problems with it? #7
Or they will come out, point you out as a nagging neighbor, do nothing about the problem and cause a neighbor feud of epic proportions, so much so you end up selling your house and moving to regain a semblance of peace and tranquility. Ask how I know..
Sent from my SCH-I500 using TractorByNet
   / Outdoor Wood Boiler, what do you have, any problems with it? #8
I would try and talk to my neighbor about this first,this would me a last resort,at least in my neck of the woods.
   / Outdoor Wood Boiler, what do you have, any problems with it? #9
My son has a Central boiler(on the third year),they have a good reputation in our area.We have two dealers in the general area and they have sold quite a few.
   / Outdoor Wood Boiler, what do you have, any problems with it? #10
I posted my experience to point out the disadvantages of living next to one of these contraptions. Local regulations are limited to the state DEC in this instance. I don't expect my neighbor to quit using his OWB and go back to buying $4.00 heating oil to be neighborly. I know people that have OWB's and other people who live next to OWB's. Needless to say, opinions vary.
An outright ban on their use between May 1 and Oct 1 or something similar would probably be something I could live with.
   / Outdoor Wood Boiler, what do you have, any problems with it? #11
Yes but the op didn't post about his neighbor getting one, he was asking for himself.
Those old smoky boilers you mention are not even legal to sell anymore in some states, and without looking it up, I believe NYS is one of those states. There is a huge difference between the old smoky ones, and the new EPA certified ones.
   / Outdoor Wood Boiler, what do you have, any problems with it? #12
Sounds like your neighbors have a neighbor just like mine.
As if the possible affects on one's surroundings shouldn't be a consideration before the fact rather than only after.
Open up your mind a little once in a while.
   / Outdoor Wood Boiler, what do you have, any problems with it? #13
I have one and am about 350 ft from my neighbors. I would never burn it in the summer. I would talk to your neighbor and if you get no satisfaction, go to your town board. You should not have to put up with that in the summer.
Just to get back on topic here, I don't really care what my neighbors think of the boiler I put in if in fact I do put one in, I am in a rural area where my neighbors are quite far away, only one of them would be in a direction where smoke may possibly blow and that wouldn't happen often at his distance from me, and the wind would have to be just right, of the people living in this area we all burn wood and one guy already has an OWB, one of the less efficient models I mentioned in my original post. Also I haven't decided on which type I would get, the new efficient models, gassers as many of you call them, or the older type like the Central Classic. I only know one guy with a gasser type and many with the older style, I don't see any problems with the smoke from the older style as long as one burns decent wood, you burn garbage or green pine, then ya they smoke pretty bad. Most I have seen smoke minimally unless they are calling for heat then they smoke some until the draft closes again or blower kicks off, whichever style you have. The fella I know with the gasser type has a brand I am not familiar with and right now cannot remember the name, it isn't a Central though, he says his has small diameter pipes which the smoke travels through and these easily become clogged with creosote if your wood is not 100% dry, he has to go out with some brass brushes on long steel rods and ream out these ports or they clog and the stove isn't able to do it's job, seems like a big pain in the ***** to me, or maybe just a poor design.
   / Outdoor Wood Boiler, what do you have, any problems with it? #15
This really depends on your neighbor. Some years ago i had a stove that would burn coal or wood. Loved the coal, my neighbors put up with it for a while then while i was leveling out a spot for them on their property, they mentions the smell. I had not idea but my smoke evidently made a bee-line toward their house and smells something like burning tires. I made it a point to burn only dry seasoned wood in it from then on.
   / Outdoor Wood Boiler, what do you have, any problems with it? #16
I have the 6048 classic and although I would not burn in the summer because of neighbors, I think the smoke issue with these is over blown. A little consideration goes a long way. The classics can't be any simpler to operate. I put wood in twice day, not because I need to, but because I find I have better control over how much I burn. I could easily get away with once a day, most of the time. I have a 3400 square foot farm house, built in 1832. Not real tight as you can imagine. Heat the house to 73 or so all winter and heat my water. The classics work great and given a choice I would go with the classic for ease of use. The gasifiers are getting better, but don't think they are as good yet. I have my own wood source, if I didn't, I don't know if it would be worth it. I burn 25 to 30 face cord a year. Hope this helps, if you have a question I did not answer let me know. I would be happy to help if I can.
Oh, I have had it for four years and no problems yet. I replaced a pump at 3 and half years. They run twenty four seven six month a year, so I don't think that is terrible.
Yes I agree with the smoke issue, I have never seen it as an issue with the boilers unless something is being burnt like garbage or wet pine wood, you have the larger Classic stove, I don't know if I would need one that large, I have heard both ways, large water capacity is good, and some claim small water capacity is more efficient, I would lean toward large capacity being better so long as the firebox is large enough with enough surface area to transfer the heat to the water efficiently.
   / Outdoor Wood Boiler, what do you have, any problems with it? #18
not to hijack the thread, but had a quick question for the op- you say that you currently have an add-on furnace in the basement, this is what I was considering getting. Besides the chimney issue and the allergy issue, are there any other reasons you would be against them? Is there really noticeable levels of smoke in the house from it? Maybe I should be considering an outdoor boiler, they are just pricey, and I think I would be more likely to get the wife to fill the furnace in the basement than to go out in the cold to fill the boiler:)
   / Outdoor Wood Boiler, what do you have, any problems with it? #19
How much wood is that in cord measure? I don't know anything about this kind of wood burner so don't know how long your wood is. Mine stove is only 14" so i imagine a face cord for my stove would be much smaller amount then what you are talking about.:)
   / Outdoor Wood Boiler, what do you have, any problems with it? #20
should only use the true cord measurement. 4x4x8=128cu/ft in a cord. If it's 14 inch wood, just do the math.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
UNUSED RAYTREE RTSG30-30" HYD STUMP GRINDER (A60432)
UNUSED RAYTREE...
Unused 2025 CFG Industrial H15R Mini Excavator (A59228)
Unused 2025 CFG...
John Deere 6110M (A53317)
John Deere 6110M...
2014 Cadillac ATS Sedan (A59231)
2014 Cadillac ATS...
