Outdoor plumbing question ?
   / Outdoor plumbing question ? #1
Code54
Elite Member
Putnam Co. West Virginia
Kubota MX5100, Kubota BX25D,1957 Farmall Cub Lo-Boy Kubota KX91-3, BCS 853
We been doing a bunch of work to the garden this year and one of the changes is adding waterlines and some soaker hoses to make watering quicker and easier.
I have a セ black water line run from the house over to the garden (Stuff from Home depot - 100ft rolls, fairly cheap). Right now they go to garden hoses but am adding some branches to the system that I want to be able to control with simple valves.
Do they make valves that can go inline on this type of pipe. I have some of the "T" and "L" fitting that slide in and you run a stainless steel hose clamp to secure and figure someone makes a valve that is similar. I have some branches I want to be able to turn on or off depending on the what we are doing and when I asked at Home Depot the guy looked at me like I was from outer space and said I had to use a brass garden hose faucet and it seems that there has to be a simpler inline valve. Anyone ever do this and what did you use?
Thanks!
   / Outdoor plumbing question ? #3
I have 1 1/2 inch black plastic roll pipe buried out into and around the orchard. I have many black plastic ball type on/off valves - located at strategic points. Got them when I bought the rolls of pipe. Got it all at either Lowes or Home Despot.
   / Outdoor plumbing question ? #4
You can get two threaded male ends - they are the type that insert into the black pipe and you secure with a clamp. You can buy fairly inexpensive plastic ball valves with female threads on each side. So it takes three parts and two clamps but works well. When I put those in, I typically do one end in the pipe and clamp, then thread on the valve, thread on the other male end, then insert into the next piece of pipe and clamp.
I am sure there are many other solutions, but these are fairly inexpensive plastic parts you can usually find at the big box stores.
Thanks everyone! I need about 10 valves so I will start checking to see where I can get a decent price.
Appreciate the help!
   / Outdoor plumbing question ? #7
look up aqua-traxx online. we began using it 3 years ago. major cut down in water use, way less weeds and very easy to use, remove and store, and reuse the next year on wifes vegetable garden.
Ill check it out, thanks
40' CONTAINER (A51244)
2015 CATERPILLAR 323FL EXCAVATOR (A51246)
2015 CATERPILLAR...
Generac Generator (A51691)
Generac Generator...
Yale MPB040-EN24T2748 4,000lbs Electric Walk-Behind Pallet Jack (A51691)
Yale...
2021 JOHN DEERE 7R230 LOT NUMBER 204 (A53084)
2021 JOHN DEERE...
UNUSED RAYTREE RMBD50-50" DRUM MULCHER (A51248)
UNUSED RAYTREE...
