Code54
Elite Member
- Joined
- Aug 20, 2005
- Messages
- 4,309
- Location
- Putnam Co. West Virginia
- Tractor
- Kubota MX5100, Kubota BX25D,1957 Farmall Cub Lo-Boy Kubota KX91-3, BCS 853
We been doing a bunch of work to the garden this year and one of the changes is adding waterlines and some soaker hoses to make watering quicker and easier.
I have a セ black water line run from the house over to the garden (Stuff from Home depot - 100ft rolls, fairly cheap). Right now they go to garden hoses but am adding some branches to the system that I want to be able to control with simple valves.
Do they make valves that can go inline on this type of pipe. I have some of the "T" and "L" fitting that slide in and you run a stainless steel hose clamp to secure and figure someone makes a valve that is similar. I have some branches I want to be able to turn on or off depending on the what we are doing and when I asked at Home Depot the guy looked at me like I was from outer space and said I had to use a brass garden hose faucet and it seems that there has to be a simpler inline valve. Anyone ever do this and what did you use?
Thanks!
Thanks!
