Out of Spec 4x4 case
   / Out of Spec 4x4 case #1
Clint S
Parish NY
555DTC Farmall 200
Well I had some issues with my tractor and it has been down each of the past 2 winters
http://www.tractorbynet.com/forums/farmtrac/226812-happened-again-ad-pto-countershaft.html
When the bolt came out this time punched a hole in the 4x4 case that I could not braze up this time. Got a new case and put to together and it made a gear noise, bought both gears for the case, still made the noise. Ran it or a while without the 4x4 gears in the new case, no noise. Old case new gears OR old gears, no noise. Ended up the the 4x4 case was out of spec causing the gear in the tractor and the gear in the case to mesh too deep. A 1/32 gasket fixed the issue.
Hopefully everything stays together this time around.
Fast 9613N 1300 Gallon Sprayer (A57148)
Fast 9613N 1300...
3PT HAY FORK (A52708)
THREE POINT WYLIE SPRAYER (A58214)
THREE POINT WYLIE...
NEW Skid Steer Attachment Plate (A59000)
NEW Skid Steer...
ALLMETAL MOBILE PRESSURE WASHER (A58214)
ALLMETAL MOBILE...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
