Out of Spec 4x4 case
   / Out of Spec 4x4 case #1
Clint S
Veteran Member
Parish NY
555DTC Farmall 200
Well I had some issues with my tractor and it has been down each of the past 2 winters
http://www.tractorbynet.com/forums/farmtrac/226812-happened-again-ad-pto-countershaft.html
When the bolt came out this time punched a hole in the 4x4 case that I could not braze up this time. Got a new case and put to together and it made a gear noise, bought both gears for the case, still made the noise. Ran it or a while without the 4x4 gears in the new case, no noise. Old case new gears OR old gears, no noise. Ended up the the 4x4 case was out of spec causing the gear in the tractor and the gear in the case to mesh too deep. A 1/32 gasket fixed the issue.
Hopefully everything stays together this time around.
2017 Ram 4500 Bucket Truck (A51039)
2017 Ram 4500...
2018 NISSAN TITAN PICKUP TRUCK (A51222)
2018 NISSAN TITAN...
2012 MACK CHU613 (INOPERABLE) (A50854)
2012 MACK CHU613...
Bus (A50323)
Bus (A50323)
2018 PJ  30+5 GOOSENECK TRAILER (A50854)
2018 PJ 30+5...
2018 BIG TEX 35+5 T/A GOOSENECK (A50854)
2018 BIG TEX 35+5...
