Our Backyard
/ Our Backyard #1
pdxman
Scappoose, Oregon
Kubota B6200 HST
Came across a $60 digital camera this weekend and thought I'd give it a shake. This is the horse arena my brother in law and I built a year and a half ago. Will try to get a front yard picture when the overcast clears.
/ Our Backyard #3
Nice place and not bad pic for $60!
/ Our Backyard #4
Pdxman,
Great looking arena!!! The only thing I would be careful of is the boards that are nailed on the outside. Horses can get to pushing on them and knock them off. Also if you ride in there I've had as patients and seen broken legs from the horse getting too close to the posts and knocking the leg against the post. I would run a board on the inside where you built your retaining wall just for safety reasons. GREAT looking though.
/ Our Backyard
The boards mounted on the outside of the posts are on pretty good. We nailed them plus lag bolted them on. I have had visions of someone hitting their leg on one of those posts and need to do something about it. When I got home last night my wife told me about her day watching my 12 yr old nieces horse completely fall and roll on her. Both a little bruised and swollen but ok. Horse (6yr Arabian) may have aggravated a previous leg injury causing the fall.
The camera is just a simple Intel PC pocket cam.
/ Our Backyard #6
Great picture and great arena. How much farther does your hillside go up? How did you make your retainer wall? I'm going to be building several retainer walls and I plan to sink posts into the ground and even pour concrete footings in some areas. When I saw your arena, it looked like you had some similar challenges.
JimI
/ Our Backyard
Thanks JimI. We live on a hillside so the slope continues up...and down. Posts for the retaining wall were 18 foot treated 6x6 cemented in the ground about 3-4'. Backside of the wall that was trenched had about 2-3' space and left compacted native ground undisturbed as much as possible. Treated 2x6 were lag bolted from the trenched area side. Put 'deadmen' on each post by using a long threaded eye bolt through each post with the threads coming out the arena side. In the 'eye' side of the bolt we bent heavy 10' rebar to hold onto it and bent an 'L' on the other end and anchored in cement. That way, during normal settling, we can crank on the nut on the arena side to pull the wall back in some. Haven't needed to do this in awhile as I think it's pretty much settled into place. We also put some roofing felt in the bottom of the trench with drain pipe on top. Backfilled with drain rock. I tell you what though, when using those long treated posts, no matter how straight you put them in, once they started drying and sun gets to them, they really get twisted. Guess thats one of the problems of doing something yourself and tend to notice it more than someone else. Another thing to remember, we put the 2x6 boards in wet and butted up tight. This pretty much allowed for maximum swelling and avoided any buckling caused from it. When they dry out though, I can see some half inch gaps between the boards so be sure to allow for this. Anything else, just ask
/ Our Backyard #8
You sure did your homework and built that wall right pdxman. That's exactly how I did mine except I used railroad ties because I had them and didn't have to buy them. I really like your look alot better though. No shortcuts and quite the professional look.
/ Our Backyard #9
Pbxman, thanks for the info. I'm going to save your description to refer to when I start doing my retainer. Mine is along a path I cut beside a pond. See attachment.
JimI
/ Our Backyard #11
Harv, the "tiltmeter" says, "Go straight up and down; don't even think of sideways." I have a real tolerance for these hills as long as I'm not leaning to the side (I've spent many hours hanging on the sides of radar antennas on a rolling ship). However, I admit posing my tractor where I normally would not go. I put the boxblade and FEL down and set the parking brake before getting off to take this picture. I could just see it rolling backwards into the pond as I stood there helpless with camera in hand. I don't want to take any pictures of a "submarine" tractor. /w3tcompact/icons/shocked.gif/w3tcompact/icons/blush.gif
JimI
/ Our Backyard #12
Last time I got on a slope like that I ruint a pair of Fruit of the Looms!
Alan L., TX
2008 INGERSOLL RAND G240-191KW GENERATOR (A63276)
2008 INGERSOLL...
ATS Mini Excavator (A66285)
ATS Mini Excavator...
250 GALLON FUEL TANK (A64276)
250 GALLON FUEL...
2021 CATERPILLAR 279D3 SKID STEER (A62129)
2021 CATERPILLAR...
KUBOTA SVL97-2 SKID STEER (A65053)
KUBOTA SVL97-2...
CASE 610 Sprayer System 2000 Gallons (A63688)
CASE 610 Sprayer...
