Ouch. tree gets revenge
   / Ouch. tree gets revenge #2
Being old and fragile these days I try to think SAFETY before doing almost anything. I try to think SAFETY when responding here on T-B-N.
Here is a guy using improper equipment, risking a $500,000 medical bill plus possible crippling for life.
Mr. Natural says: GET THE RIGHT TOOLS.
   / Ouch. tree gets revenge #3
NOT ME!
Agree! It is obvious the end of the branch is going to hit first and then the base has to go to one side of the tree or the other. not the sharpest tool in the shed!
   / Ouch. tree gets revenge #5
What a dumbass. He did a lot of things wrong, but had he made a short undercut first, it would have been a much different outcome.
   / Ouch. tree gets revenge #6
"Get out of there guys, I don't want to hit no one. Everybody Good?"
Uhm....Apparently not :rolleyes:
   / Ouch. tree gets revenge #7
I won't use a chainsaw on a ladder. I've gone up a ladder with a chainsaw intending to use it, but it didn't feel right. Just way too many ways for that to end poorly.
   / Ouch. tree gets revenge #8
That is why I don't like to make cuts from a ladder. Even with proper technique, there just isn't anywhere to go when things go wrong and Murphy's Law is always in effect even on the best laid out plans.
   / Ouch. tree gets revenge #9
Was the saw hurt? It took a pretty good fall also. All joking aside, chain saws scare the crap out of me and I've used them quite a bit. I'm pretty sure it says in the owners manual never to use one for a ladder. I'd have just cut the entire tree down if that one limb was bothering me. The correct way to do it would be from a bucket truck or someone that knows how to climb a tree.
   / Ouch. tree gets revenge #10
Some tree cutting stories:
1. One of my old commanders used to tell of a fellow clearing trees after Hurricane Hugo (1989, South Carolina) and this fellow was straddling the trunk of the tree he was cutting. It was caught up with some other trees and when his cut went through the tree he was on it in turn acted like a catapult or in this case a manapult. It tossed him over a couple of houses. Needless to say, he never cut anything again.
2. A LtCol I knew at my guard base was cutting a tree down and it fell over. He was making another cut to complete the job and the trunk was under pressure. His second cut released pressure and it whipped, hit him in the lower leg and severely broke both bones. He was out of action for several months.
A couple of ladder stories:
1. Mine - I was on a ladder. My head was at about 18ft putting my feet at about a 12ft level. I was about to feed an antenna cable into a building through a weatherhead. When I opened the weatherhead a swarm of wasps came out (see wasp nest below. It was in a 4" pipe.) and directly for my head. My brain reacted before reason stepped in and I found myself in mid air thinking "this is gonna hurt."
I landed on the concrete base pat for the antenna tower directly on my heels. End result was two crushed heels, a broken ankle, 4 months in a wheelchair, and 4 months of rehab. I was lucky in a way because the wasps came at me from an angle so I jumped away from them. If I had jumped straight back I probably would have contacted the antenna tower, tangled my feet in it and came down head first.
2. In the summer after I got back to work a contractor was doing some wasp eradication on our building and was on an extension ladder at about 30ft. Wasps came at him and somehow he came off the ladder and landed on the ground directly on his back. On the way down one of the latches that keeps the ladder extended caught him on the leg and gashed him through his calf all the way to the bone. We never did hear what became of him after the ambulance took him away.
About a month after that a swarm of bees decided to make our building a home in various places. One place was the antenna tower I had been hurt by and the other was approximately where the other fellow had been hurt. No-brainer this time - a pest control agency was called that had a high pressure sprayer and there were no ladders involved.
2019 FORD F-650 SUPER DUTY BOX TRUCK (A51406)
2019 FORD F-650...
2016 Nissan Altima Sedan (A50324)
2016 Nissan Altima...
2016 TROXELL 130BBL VAC TRAILER (A52472)
2016 TROXELL...
2013 MACK ELITE LEU 633 GARBAGE TRUCK (A51406)
2013 MACK ELITE...
2017 Ford F-150 Pickup Truck (A50323)
2017 Ford F-150...
