Ouch! Replace Nimco 2S-40272 Loader Ctl. Valve w Brand LV22 / Surplus Ctr. 9-7401?
   / Ouch! Replace Nimco 2S-40272 Loader Ctl. Valve w Brand LV22 / Surplus Ctr. 9-7401? #1
caine
There have been a few threads on this site about replacing a Nimco 2S-40272 loader control valve with a replacement, and most of the dialogue I've found has centered on the Brand LV22 valve as a replacement. I've just come through a painful lesson that I thought I would pass on in hopes of sparing you some of the difficulties I experienced.
First of all, it seems that a lot of guys are saying that the Surplus Center's BRAND Model LV22RFSTKAB (9-7401) valve is a direct replacement for the Nimco. Unfortunately, it's not that simple. It depends on how your valve is mounted.
First, let's take a look at the two valves, side by side, Nimco on the left:
You can see that the Nimco is substantially beefier than the Brand. I don't know if that actually affects function or durability though. My Nimco has just over 300 hours on it (9 year old TYM tractor) and has blown o-rings regularly since I bought the tractor (used) in 2010. I finally gave up repairing it and decided to replace it. When I saw that the Brand valve was about half the mass, I was a little concerned. But then I figured the Brand would certainly give me 300 hours of trouble-free use, wouldn't it?
There have been some erroneous suggestions that you can mount the Brand LV22 valve any way you need to and just reroute the working hoses so that your bucket operates correctly. That is not really true. I got that advice from threads on this website, but also I ordered the valve from Northern Tool because their sales rep told me the same thing. Northern Tool has since issued me an RMA because that has proven to be incorrect information.
My Nimco is mounted from the top- i.e. the valve sits below the horizontal mounting plate. If you read the documentation on the Surplus/Northern/Brand valve, you see that it is intended to be mounted to the left of a vertical mounting plate. The reason it matters is that in addition to the boom raise/lower and bucket curl/dump functions, there is a float position (top, past the detent) and a dump regen (past the dump detent to the right).
If you rotate the valve 90 degrees to mount it from the top (which I tried- see photos), you can reroute the hoses so that the boom raises and lowers and the bucket curls and dumps as expected. But you CAN'T move the "float" and the "rapid dump" functions. So you end up with a "float" position at the left extreme of your bucket curl (which makes no sense) and a "dump regen" function past the boom lower position which causes the boom to rapidly raise!! Yes, to learn this, I went through through the complete process of drilling new holes, mounting the valve with spacers, getting adapters for the inlet and outlet lines, and trying it out! :thumbdown:
This photo shows how the valve is positioned below my mounting plate, and specifically how I added a nut and some washers to position it lower than the Nimco, so that the inlet and outlet hoses would line up with exisiting holes in the mounting plate (left and right sides).
This photo shows the completed installation, which is now dismantled so I could return the valve.
Imagine my surprise when I lowered the bucket and pushed the control handle past the detent intended for be used for rapid bucket dump, and the boom went up rapidly!
There is no field modification to move the float and dump/regen behavior. So if you want these features, you cannot use this valve in any position other than the one called out in the diagram. This means that to use it, you have to rotate your mount 90, 180 or 270 degrees to make it work. For me, that was a lot more trouble than re-ordering the correct valve.
Here's the diagram for the Surplus 9-7401. Notice that the mounting plate is vertically oriented, and to the right of the valve. This is where it HAS TO BE for this configuration of the valve.
According to diagrams published by Brand Hydraulics (complete set at http://www.brand-hyd.com/lv/catalog.pdf), if you are mounting the valve from the top, you specifically need the LV22RFSTKA2B version, and guess what- neither Surplus Center nor Northern Tool sell it. This means you need to find a Brand dealer and order it from them- which is what I will be doing today.
I also looked into the Prince valve carried by Surplus Center and realized that it is intended to be mounted with the mounting plate below the valve. So unless you are OK with changing your mount, you cannot use the 9-7401 valve from Surplus Center (or same from Northern Tool). Instead, you need to locate a valve configuration that matches your mounting situation in order to get the float and the bucket dump/regen in the correct position.
I'll put up another post once I get the "correct" valve and verify how it works. I am concerned that it appears to be light duty compared to the Nimco, but then again, as well know, size doesn't matter. :thumbsup:
   / Ouch! Replace Nimco 2S-40272 Loader Ctl. Valve w Brand LV22 / Surplus Ctr. 9-7401? #2
You are probably talking about me as I did say it should mount in just about any position.
I am sorry if my comments led you to a wrong conclusion.
Mainly I was referring to the functionally of the valve, but as far as physical mounting, you have to mount it to their specs.
Could you not make or modify the mounting plate for the Brand valve?
With a different manufacturer, you usually do have to modify the holes, mount direction, or do what you have to do to get it to work.
I don't believe I ever said it was a direct replacement.
Again I do apologize for your troubles.
On some valves, you can reconfigure the valve as to the mounting.
JJ- I don't think you ever said it was a direct replacement either- so please don't worry about it. I'm certainly not blaming anyone- it's just a learning experience that I hope to help others avoid.
It's one of those things that's obvious once you are familiar with the topic but was not obvious to me- because I am new to the details of hydraulics (even though I'm pretty mechanical).
And so when the sales rep said it could be mounted in any orientation, I felt like I had "consensus" and went ahead. What I didn't understand and was trying to convey in a helpful way is that there's a difference between being able to swap the working hoses around and truly being able to configure the valve to work in any position- and that's something to clarify and verify before purchasing.
I have no facility for working with heavy steel plate, so making a new mounting bracket would have required drawing something up, taking it to a shop, painting it, etc. I decided it was easier to just get the right valve. Unfortunately, even the manufacturer was out of it so I had to belly up to the bar with an expedite fee. So I'm out some shipping charges- but I *should* have a direct replacement (other than the location of the original mounting holes) late next week.
   / Ouch! Replace Nimco 2S-40272 Loader Ctl. Valve w Brand LV22 / Surplus Ctr. 9-7401? #4
Some valves come wit ha "universal" joy stick mounting option. This allows you to mount the valve in basically any position and then mount the joystick to provide the "standard" operating motion. The actual valve ports must always be connected properly to give the correct movement.
I am not sure if Brand offers this feature on this valve or not.
It's been quite a while since I added my last post on this thread, but I owe you all some feedback as to how things came out. I've been offline because of a couple of major family issues.
I did receive the correct LV22 valve- the LV22RFSTKA2B which is designed to be mounted beneath the mounting plate (see the documentation link earlier in this thread). I connected the hoses and it worked as advertised- although I have not used it under much load yet.
I guess it must not be a common mounting configuration because no one stocks a similar valve that is designed to be mounted under the mounting plate. Brand Hydraulics said I had to go through one of their distributors. Applied Industrial Technologies is a national firm ( that has an office here in Eugene, OR. I ordered through them- and paid a rush fee. I had the valve in about a week- they kept me fully informed through the process. So this was not a consumer off-the-shelf / overnight experience, but I thought they did a good job.
Once the dust settles in my family life I'll put the loader to serious work and report back.
   / Ouch! Replace Nimco 2S-40272 Loader Ctl. Valve w Brand LV22 / Surplus Ctr. 9-7401? #6
Good to hear you got it operational again... Thanks for the follow up info...
   / Ouch! Replace Nimco 2S-40272 Loader Ctl. Valve w Brand LV22 / Surplus Ctr. 9-7401? #7
I know this post is old, but I don't believe the OP's original statement that "There is no field modification to move the float and dump/regen behavior" is correct. While I'm not certain about this particular valve, in most monoblock valves I've worked on, you can move spools and detent kits from one location to the other. I would agree that this is not a task that someone new to hydraulics would want to tackle. However, on this particular Brand Hydraulics valve you can re-orient the joystick to different configurations to meet your mounting needs. See Brand Hydraulic's conversion instructions at these links.
You can convert between A & A1 or A2 & A3 configurations directly. To convert from the A or A1 configs to the A2 or A3 configs, you will have to order the LV60 boot mounting plate. Or the LV22 boot mounting plate if you going the other way. These are basically the same part with the joystick anchor point in a different location. See drawings in the conversion instructions.
I believe this to be true, but if you think I'm wrong, please correct me.
   / Ouch! Replace Nimco 2S-40272 Loader Ctl. Valve w Brand LV22 / Surplus Ctr. 9-7401? #8
Spools are fitted to a specific bore, and and no replacements are made for that bore.
A good craftsman might be able to machine a bore and fit a spool, but unlikely.
When a spool starts leaking bad enough, you replace the valve.
   / Ouch! Replace Nimco 2S-40272 Loader Ctl. Valve w Brand LV22 / Surplus Ctr. 9-7401? #9
For a Massey 1242 Loader (used on Massey 1215 Diesel Tractor)
1. Requires Brand LV22RFSTKA2B available from:
Federal Fluid Power Outlet store:
federalfluidpower on ebay (Based in United States, federalfluidpower has been an eBay member since Dec 04, 2006)
Link is available at Hydraulic pumps, hydraulic motors, hydraulic cylinders and other hydraulic parts from Federal Fluid Power - Detroit area, Michigan, products, Brand Hydraulics, click on visit our outlet stora.
2. Requires drilling two new holes and two 3/8 inch spacers(so the in and out side hoses will fit the bracket slots)
place the front edge of the valve body against the front edge of the bracket and mark for the new holes. Picture attached.
3. Requires two new bolts and nuts 1/2 inch shorter than originals
4. Requires two steel hydraulic adaptors (4000 PSI) 8MB to 10FB (8 gallon/min male Boss and 10 gallon/min female Boss) with o-rings
Note that all six ports on the new spooler are 8 GPM O ring female ports.
THE ONLY PROBLEM SO FAR
If you are lowering the bucket and push the lever to the high speed detent, when the bucket presses the ground, it will reverse
and start up. However, I am content to deal with that issue rather than spend $700.00 plus dollars on another Nimco which will
blow its gaskets and o-rings regularly.
The Brand Valve was $190
   / Ouch! Replace Nimco 2S-40272 Loader Ctl. Valve w Brand LV22 / Surplus Ctr. 9-7401? #10
Hey Caine,
Getting ready to do the same thing to my 1464. I know it's been a few years but can you follow up on that final installation of the "2B". I've ordered the MF rebuild kit one more time to hold me over until I can afford the new valve. Thanks for the great information!
1972 Baker 30ft Pole S/A Towable Trailer (A51692)
1972 Baker 30ft...
1985 International 1754 Material Spreader Dump Truck (A51692)
1985 International...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2014 DRAGON PRODUCTS STEPDECK 46 DOVETAIL W/RAMPS (A53843)
2014 DRAGON...
2019 KUBOTA KX057-4 EXCAVATOR (A51246)
2019 KUBOTA...
RYOBI 40V BRUSHLESS ELECTRIC 20" PUSH MOWER (A51248)
RYOBI 40V...
