OSB Roof and Wall Sheating - ZIP System Recomendation
   / OSB Roof and Wall Sheating - ZIP System Recomendation #1
Beltzington
Platinum Member
Appling, Georgia
JD 3720
Many of us have or will build sheds, garages even houses. For future builds I highly recommend you look at the Huber ZIP System based on my personal experience. Last year I started well pump house project knowing full well it would be several months before I completed it. Part of the project was to test materials and techniques I may incorporate into building a house. For the roof and walls of the pump house I used ZIP 1/2" (red) sheathing, the "system" is their proprietary sealant already applied to each sheet and their seam tape. This system does away with having to use house wrap or felt. They warrantee their sheathing against delamination for 180 days fully exposed to the weather.
Well I can attest it works, my roof and wall are still exposed and it has been over seven months. The sheathing has seen a couple ice storms, many, many rainy days and most impressively has been baked in the hot Georgia sun with no damage to the wood and the tape is still firmly attached.
Sheets are a couple more dollars than standard OSB but in my opinion work perfect for jobs that won't be dried in right away.
Huber Avantech Flooring seems just as good although I cannot attest to it's wx resistance.
   / OSB Roof and Wall Sheating - ZIP System Recomendation #2
When a small branch, <1 inch, put a hole in my roof, I quickly ripped up the OSB and put in regular plywood. The OSB flexed when I walked on it and the plywood does not. No problems since.
VOLVO EC240CL LONG REACH EXCAVATOR (A52705)
VOLVO EC240CL LONG...
2006 Toyota Tundra 4X4 Pickup Truck (A53424)
2006 Toyota Tundra...
2010 Chevrolet Traverse (A55758)
2010 Chevrolet...
2022 CATERPILLAR 242D3 SKID STEER (A51406)
2022 CATERPILLAR...
2015 Big Tex 70PI 15ft Pipe Top T/A Utility Trailer (A50322)
2015 Big Tex 70PI...
