o'rings
   / o'rings #1
robert j
mason nh
yanmar 336d
So I have a new controller for my front end loader a yanmar 336d . called my local yanmar dealer looking for replacement o' rings for the fittings on my old controller .was going to use them on the new one . bought the new controller from hoye. it lists the ports as in/out ports sae #8 o'ring and the same for the work ports . the fittings from valve to jic #6 to loader lift and curl hoses. and fitting from valve to jic #8 inlet and outlet fittings . well this is the third time I have called about parts with no response back . really they just must be that busy. I will just use some sort of sealant if o' rings are bad and hope for the best Monday I will try to find them on line . do you all think o' rings will be ok or just wasting my time . winters coming fast and need tractor for plowing out my camp. thank you bob .v. :confused2::confused2::confused2:
   / o'rings #2
I guess I am not sure what you are looking for. You are looking for the orings for the #8 fittings? Any local industrial supply place should have those. I would not use sealant in place of the oring. Are you saying you have called us 3 times with no return call or your local Yanmar dealer?
   / o'rings
no my local yanmar dealer. I read that hydraulic o' rings are made different than standard o' rings . if they are the same as automotive than I can get them.
   / o'rings #4
As long as you don't get something special like air conditioning o-rings they should be just fine for what you are doing as long as you get the right size. The hyd fitting o-rings are usually a slightly harder rubber but I've always just used regular orings on my hydraulic fittings and have never had a problem.
   / o'rings
thank you very much . now if I can get the dealer to call me back ?
   / o'rings #6
Just FYI if you don't have a convenient local supplier, these folks usually ship very quickly, priority mail for small stuff .... Page with SAE ORB fitting O-rings (the fitting on 99% of FEL valves bodies).
Buna is good for down to -25*F if you live in a very cold climate, Viton is rated for higher temps rarely if ever seen with ag hydraulics but tends to get hard and (relatively) brittle below -5*F (I'd stick with Buna).
As mentioned, you definitely don't want to use some sort of sealant-hack in this application - a pinhole spray of hydraulic fluid under pressure is often difficult to see and a very dangerous thing that easily cuts clothing and skin doing great harm.
   / o'rings #7
If it wasn't leaking they will probably be okay to reuse. I bought all three assortments (metric, SAE, and AC) from Harbor Freight and usually find one that will fit. I'm not opposed to using AC o-rings if they fit proud in the groove.
   / o'rings #8
Many of these O rings in various places on these tractors are Japanese spec O rings...not even metric but a special size. Several I have had to get from Hoye cause I could not source any local even at big industrial parts houses.
I have pitched the idea to Hoye about making up an oring kit to sell. Something with all the common ones in there. Since I have their ear again with this post I will bring it up again!! Aaron, I know I would buy one if it was availible, the next order I had, nothing worse than not having one when you need it and your part guy is a 3 or 4 day delivery away!!!
   / o'rings #9
You are confusing the issue. The OP needs SAE 8 o rings.
   / o'rings #10
You are correct! And no I am not confusing the issue other than for folks not following well. I know exactly what he needs and there talking about. But I am useing this thread and the fact that aaron has posted here to pitch my idea of a Yanmar specific O ring kit. But thank you for clarifying it for folks who may not be clear on the subject.
2018 Bobcat T595 (A47384)
2018 Bobcat T595...
2014 HINO 338 26FT CDL REQUIRED BOX TRUCK (A52576)
2014 HINO 338 26FT...
https://www.globenewswire.com/news-release/2025/05/08/3077245/0/en/Nerve-Calm-Complaints-Investigated-2025-User-Reviews-Tested-Verified.html
https://www.globene...
ATLAS 84" BOX BLADE (A51243)
ATLAS 84" BOX...
2000 Mercedes-Benz S-Class Sedan (A50324)
2000 Mercedes-Benz...
1994 Prevost Liberty Coach Motorhome (A51694)
1994 Prevost...
