Oregon G6 blades for RC72R deck
   / Oregon G6 blades for RC72R deck #1
Capt.Ron
I'm looking to get new blades for my F2560 with the RC72R deck. I found these and they seem to fit according to the dimensions but it doesn't say on their site that it fits this deck.I think the blade is a little thicker, wider and longer that OEM blades.
Has anyone ever used these or this brand?
Would you use them again?
Do you have a better recommendation?
Thanks!
   / Oregon G6 blades for RC72R deck #2
I run G6 Oregon blades on my ZD326 and really like them. I think they are better than stock Kubota blades
   / Oregon G6 blades for RC72R deck #3
   / Oregon G6 blades for RC72R deck #4
I put them on my BX25 RCK54P23BX this year. All good so far. Yes they are thicker.
   / Oregon G6 blades for RC72R deck #5
You need 20-1/2 length for a 60" deck. 20-1/2 blades are a little longer than stock blades, but as long as you're deck isn't dented they'll work. I run similar blades on my machine. I'll see if I can't find a number for you. They are pretty heavy. I accidentally ran over a highway mile marker with these blades. My Kubota running these blades digested it with only a minor nick on 1 blade. If it was a MTD it would have probably warped the deck.
   / Oregon G6 blades for RC72R deck #6
They are thicker and wider than the stock blades on my ZD. Seems to do a great job and I believe they are hard surfaced as well
Mine is a 72" deck.
   / Oregon G6 blades for RC72R deck #8
I have been researching those blades for my F2690 with the same deck as yours and from my determination we need the 24 1/2" X 2 1/2" blades with the 1 1/8" center hole. The Kubota part number is K5698-34340 and if you look for K5698-34340 dimensions you get what I posted. Oregon 396-814 is what we need.
There in lies my question. the Oregon 396-814 is 3" wide, not 2.5" and is 24.525" long, not 24.5" long. Also if you look at what part numbers it replaces I don't think it lists the oem number for this deck. Now the difference in size was intentional to make them sturdier and last longer. What I don't know is whether or not that slightly larger size is enough to cause the blades to touch when they are spinning. that 0.025 translates into 0.050" less distance between the center blade and the outer blades. As long as they don't clip each other while rotating I would think this would give us a better cut and I believe these blades create better lift which in turn could give a better cut. My current blades are worn enough that I sometimes have a thin line of uncut between the blades.
   / Oregon G6 blades for RC72R deck #10
Incorrect. ITs still 0.025" less gap between blades.
The total blade lenght is 0.025" longer.....which means each blade tip 0.0125" further from the center hole.
Kinda like confusing differences between diameter and radius.
I would certainly think that 0.025" isnt gonna mean squat. Thats about 8 sheets of notebook paper. And if it is an issue, about 2 seconds on the tip with an angle grinder will remove the needed 0.0125"
DOWNING MANUFACTURING BITUMINOUS APPLICATOR (A51406)
DOWNING...
PALLET OF MISC SIZE EXPANDED METAL (A51247)
PALLET OF MISC...
2017 Kia Cadenza Premium Sedan (A51694)
2017 Kia Cadenza...
2015 Ford F-550 4x4 Knapheide Service Truck (A51692)
2015 Ford F-550...
UNUSED FUTURE FT15J EXCAVATOR (A51247)
UNUSED FUTURE...
(NEW) 2025 DOWN 2 EARTH GOOSENECK TRAILER (A51247)
(NEW) 2025 DOWN 2...
