Orec tracked flail vs Grillo wheeled flail vs ride on
   / Orec tracked flail vs Grillo wheeled flail vs ride on
I have used goats to clear areas of kudzu on the farm before. The drawback is there would be a lot of labor installing a good goat fence on this hillside. This hillside isn't kuduz infested, but it grew up in thorns and saplings due to not being mowed periodically.
This other hillside is infested with kudzu. Goats would actually be the better long term option for clearing the kudzu off because they eat it down to the point that they actually kill it where mowing doesn't actually do that. Or I can mow/spray it and the spray will kill the kudzu.
The last time I fenced for goats, I ran several strands of electric wire and that worked so long as I kept the charger battery charged and kept weeds off the wire. Standard field fence would be more secure, but 330' of standard field fence weighs 192 lbs where goat fence with the smaller openings weights 261 lbs which feels noticeably heavier to handle to me.
What is new to me is the temporary goat fencing made from electrified mesh and lightweight step in posts. I haven't used them myself. They are something I have on my list to learn more about before making a decision on what to do next.
   / Orec tracked flail vs Grillo wheeled flail vs ride on #132
Hi again 2manyrocks ;)
Spending a large 5-digit sum of money to keep the weeds off this one hillside only, is indeed hard to justify - and on top you have to do the work yourself! :unsure:
On my 6200 m² (around 1.5 acre) meadow, I have tried a few different solutions over the years. I usually mow twice a year with my BCS 740 2-wheel tractor and my Zanon drum mower, but have also done it once with a sickle bar mower instead. Then I rake the grass into swaths by hand, and finally I gather the grass and leave it on a handful of heaps at the edge of the plot to decompose. The mowing is the easy part, but as I don’t get younger, the rest is getting harder and harder :cry:
I have no experience with goats, but 2 month ago I had 80-85 sheep „shaving“ my meadow as a test. A professional shepherd in my area brought his animals to me for 5 days. As I have no fence around my meadow, he put up a temporary fence of the sort that you describe:
I have no experience with this sort of fencing, but as the shepherd constantly travel this area with his herd, and often stays only a day or two on each plot, he has to be able to put it up and down very quickly. The sheep had a lot of respect for the fence and always kept a safe distance.
This might be a possibility also in your area, and like with your contractor with the mulcher, you don’t have to invest in anything, and an experienced person will even do the job for you.
Best regards
Jens
I haven't used it, but have read that is the style of temporary electrified shock mesh fencing that is the easiest to install for goat containment.
Another idea I've considered is using a winch to lower and raise a towable ATV style mower up and down the hillside, but the hillside terrain varies so much that steering control would be needed. I think this would also be time consuming even if I figured out how to add remote control steering to a towable ATV mower. Or perhaps there is a way to add a guide cable to keep the mower mowing on a certain path?
The larger robotic self propelled Spider mower is advertised for roughly the same almost $40,000 price in the USA as the Power Trac PT1445.
   / Orec tracked flail vs Grillo wheeled flail vs ride on #134
Update: I hired a company who used a Cat299d equipped with a Cat mulching head to clear this slope.
It was money well spent because they were able to grind up even some small trees on the slope in only a few hours that would have otherwise turned into a chainsaw job plus having to drag the debris off the hillside. It also made a difference that the operator was experienced operating this equipment on slopes.
The mulch residue left behind is pretty deep in places, and there are still some shattered tree stumps here and there.
Now that I am able to walk on it again, I feel like I need a ride-on solution of some kind or a remote control cutter because I doubt I can personally handle using a walk behind to maintain this slope.
Before as seen from top of hillside:
After as seen from bottom of hillside:
Curious how progress has been? What have you done to maintain the land? What's it look like now? Most important - Did you get a 2-wheel tractor??
I bought a power trac pt1445 because it would be a lot of physical work using any 2 wheel machine and I dont like the idea of running into snakes on foot. I saw one rattler mowing with the pt1445 last year. Neighbor saw another in our fence line last week.
There are still steep areas I cut with a echo brush cutter during the winter that might yet be easier cut with a 2 wheel walk behind or remote control cutter.
2014 Dodge Avenger Sedan (A53424)
2014 Dodge Avenger...
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
UNUSED Heavy Duty Ratchet Strap Set (A53117)
UNUSED Heavy Duty...
2021 KOMATSU D71PX-24 CRAWLER DOZER (A52707)
2021 KOMATSU...
2020 Deere 325G (A50123)
2020 Deere 325G...
AGT INDUSTRIAL HYD STUMP GRINDER (A52706)
AGT INDUSTRIAL HYD...
