Ordering remotes, now what TNT cylinders??
   / Ordering remotes, now what TNT cylinders?? #1
sikmusicfreak8
Anza, CA
2005 Branson 4720, 8620 Backhoe
Ordering the dual remote kits, just*wondering if anybody has*cylinder sizes for the top and tilt for these tractors? Ive got an 05 4720.*
Thank you very much!
   / Ordering remotes, now what TNT cylinders?? #2
You'll probably find a pretty unanimous recommendation on here for Fit Rite Hydraulics. Mtnviewranch here on the forum.
I've been overly satisfied with mine and can't speak highly enough of Brian (the owner.)
Ive spoke with him before, and looked his page over today. Just wondering what size other members are running with their*Branson. *
   / Ordering remotes, now what TNT cylinders?? #4
"Top and Tilt"?????
On guessing, the end caps are non inclusive. Figure 1-2" for packing for the length reduction and ⅛ to ï½¼ for wall thickness for diameter reduction. Take the radius (half the INSIDE diameter) square it (multiply it by itself) and multiply that by the length and you have the volume in cubic inches. If you are moving a pair of cylinders multiply that answer by 2 for total flow.
A gallon is 231 cubic inches. Look up your flow rate from your tractor's spec sheet. It will be in gallons per minute (gpm). Divide your cylinders volume by 231 and you have gallons. Divide that by your flow rate and you have minutes or a fraction thereof. That is how long you can expect your cylinder to cycle....pretty much since you have cables to consider and the volume of the cylinder is less on extending than on retracting (due to the presence of the rod in the extend function reducing the internal volume) making it extend faster than it retracts.
On size of controls and hoses, length at a minimum to improve cycle time. Smaller diameter hosesis weighted against volume required by cylinder....⅜ dia hose contains less fluid to move so is faster in that sense but takes twice as long per unit length to move the same volume (cylinder required amount )of fluid than the ½" hose.....gets to be a crap shoot.
Control, all of mine are open center, spring return as the application requires, and ½" plumbing except for OEM Branson loader joysticks and hoses. I use ½ on all my implements.
Thanks for the reply, I will be looking more into this
   / Ordering remotes, now what TNT cylinders?? #6
Just for reference, I have a top cylinder for my 4720CH on order from Brian at Fit right (3- 1/2 mo delivery!). It is 2-1/2" cylinder dia, 1-1/2" rod dia and a variable length from 21-1/4 to 31-1/4 inches. That cost about $400 delivered and includes with hoses, connectors and flow restrictors. My tractor came with two sets of rear hydraulic ports, one with a float option and one without. The top link will be hooked to the floating control. I would like to get a side tilt for the non floater, but am waiting to see how much I like the top link. The side tilt I think will cost a bit more because of the custom made cylinder ends. Hope this helps.
Lead time was my first deterrent, and price. No doubt its quality stuff, but if I cant get the factory remotes at a reasonable rate, Ill build my own setup. *
2025 IR IRMC 8D UNUSED Massage Chair (A53117)
2025 IR IRMC 8D...
AEROQUIP PROOF TESTER (A53843)
AEROQUIP PROOF...
2022 MAXXD BD14 Heavy-Duty Dump Trailer with 14K GVWR and Tandem Axles (A53473)
2022 MAXXD BD14...
2023 Club Car Carryall 700 Utility Cart (A51691)
2023 Club Car...
AGT Mini Excavator Attachment Set (A50123)
AGT Mini Excavator...
2012 JOHN DEERE 10-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A53473)
2012 JOHN DEERE...
