Ordered finishing mower received belly mower
   / Ordered finishing mower received belly mower #1
leslie428
Québec, Canada
Jinma 284 LE IH 434 with loader
Shipping error got me a belly mower instead of finishing mower so I had to convert. It was easy. Just turn the drive on the mower 180 degrees and now you have a pull mower (finishing mower) You will have to make two extention bars. See pictures. Works like a charm! I have a JM 284.
   / Ordered finishing mower received belly mower #2
Leslie, I wanted a belly mower but eveyone on the forum talked me out of it because of the removing and installing. I didn't take the RFM off all summer until yesterday and I think I still would have prefered a belly mower to make turning easier. To each his own.
   / Ordered finishing mower received belly mower #3
If you have the 4 wheels to adjust cutting cutting height, that will be a good setup?--Ken Sweet
   / Ordered finishing mower received belly mower #4
</font><font color="blue" class="small">( Shipping error got me a belly mower instead of finishing mower so I had to convert. It was easy. Just turn the drive on the mower 180 degrees and now you have a pull mower (finishing mower) You will have to make two extention bars. See pictures. Works like a charm! I have a JM 284. )</font>
Congratulations !!!
Generally speaking, it's NOT so easy to convert a finishing mower to a belly mower as you said.
   / Ordered finishing mower received belly mower #5
</font><font color="blue" class="small">( See pictures. )</font>
All I can find is one shot of a red bracket. Kinda hard to feature what you're talking about based upon that alone.
//greg//
   / Ordered finishing mower received belly mower #6
</font><font color="blue" class="small">( I think I still would have prefered a belly mower to make turning easier. To each his own. )</font>
A rear mounted mower is a bit more difficult to use than a midmount, but the easy of attach/detach makes it worthwhile to me. I just treat mine like an implement that can't be turned, such as a plow. This means instead of mowing in a rectangular pattern to it's conclusion, I mow around the perimeter to get manuevering room, then I start mowing in parallel strips, just like plowing. You end up making a 180 deg turn at each end, but you don't end up with a bunch of missed strips like when you cut a 90 deg corner a little short, or rectangles with big mouse-eared corners.
   / Ordered finishing mower received belly mower #7
leslie, my mid pto is 2000rpm and rear is 540rpm. If that is the case with yours, your change will not work. Good luck.
   / Ordered finishing mower received belly mower #8
bill, there is NO WAY I would give up my MMM. I take it off in late November when I install my FEL. I remove my FEL in March and install my MMM. While it is off I do all my maintainence on the MMM. 15 minutes twice a year is a small price to pay to have the superiour performance the other 100+ ours a year I use the tractor seems like a small price to pay.
Prior to this tractor I had an 8N with a RFM. The RFM stayed on the same amount of time as the MMM on my current one.
   / Ordered finishing mower received belly mower #9
</font><font color="blue" class="small">( Shipping error got me a belly mower instead of finishing mower so I had to convert. )</font>
I just have to know. Why didn't you complain and just get the correct item sent to you?
2022 INTERNATIONAL MV607 (A52472)
2022 INTERNATIONAL...
JOHN DEERE HX14 LOT NUMBER 228 (A53084)
JOHN DEERE HX14...
2018 KOMATSU PC360LC-11 EXCAVATOR (A51246)
2018 KOMATSU...
2001 Nissan Frontier Crew Cab Pickup Truck (A51692)
2001 Nissan...
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
2018 CATERPILLAR 279D SKID STEER (A51246)
2018 CATERPILLAR...
