ORB fitting question
/ ORB fitting question #1
joeu235
Platinum Member
Little River, TX
John Deere 4020 / 6403 / 317 Ford 5600
Can you alignment of this fitting be adjusted? Like can the direction of the JIC connection be adjusted around the radial axis of the orb connection?
/ ORB fitting question #2
Yes, that is one of the purposes of ORB fittings. Put it in whichever direction is required and then snug down the nut.
/ ORB fitting question #3
Yes you can orient an elbow like shown in the picture to a desired position.
Before installing make sure the jam nut is backed off and the O-ring is located towards the top of the area without threads. Screw the fitting in by hand until the O-ring makes contact. Now turn the fitting to the desired position and tighten the jam nut. Intention is to keep the O-ring sealing on the area without threads
thanks!
Lincoln Electric Shield-Arc SAE-400 - Radiator Missing - For Parts or Rebuild (A63689)
Lincoln Electric...
2017 JOHN DEERE 3176 SKID STEER (A65053)
2017 JOHN DEERE...
66'' BUCKET WITH TEETH (A61567)
66'' BUCKET WITH...
NEW 2025 Trailer by Premiere 18'+2' Tandem Axle (A62679)
NEW 2025 Trailer...
2020 FORD F-350 (A65643)
2020 FORD F-350...
2018 Peterbilt 579 Sleeper 72" Sleeper (A62613)
2018 Peterbilt 579...
