OR-BILT Loader Question
   / OR-BILT Loader Question #1
NDRick
64 JD 3020D
Hey Folks,
Has anyone had any experience with an OR-BILT loader?
I was looking at one for a JD 425.
Thanx!! in advance for any/all replies.
Merry Christmas!!
Rick in North Dakota ... it's a dry cold
   / OR-BILT Loader Question #3
Another option to consider... Front or rear mount bucket, blade, plows etc.. dumps and resets itself automatically when reaches the top. Ball and Screw actuator (not winch) can be hydraulically or electronically powered and has a lift capacity up to 700 lbs. Mower's strength will determine actual lift capacity and lift height. This is what we use at the factory to clear the grounds, blade on front and bucket on back. The vplow in the photo is a combination blade/v-plow with tilt feature. You just pull release handle in center of plow and push to convert it to a flat blade.
   / OR-BILT Loader Question #5
Is that V-plow also a Westendorf? I did not see it on their website.
Tim
BUSH HOG 2810CD SINGLE FLEX WING ROTARY MOWER (A51406)
BUSH HOG 2810CD...
2014 STONE RIDGE 38FL 5TH WHEEL CAMPER (A50854)
2014 STONE RIDGE...
Heavy-Duty Gooseneck Hay Trailer - Built for Large Bale Hauling (A51039)
Heavy-Duty...
DOOSAN G25 GENERATOR (A50854)
DOOSAN G25...
2006 INTERNATIONAL 4300 DT466 SBA 4X2 BUCKET TRUCK (A51406)
2006 INTERNATIONAL...
PORTA CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTA CABLE 150...
