Dadnatron
Veteran Member
I recently purchased a JD 5100e with FEL 2nd hand off lease. The lease was a racetrack who used it primarily for mucking and whatnot. Pretty mild stuff overall.
I, on the otherhand, am building a farm. I've used it relatively heavily... at least the FEL, for around 100hrs thus far. Lots of back and forth with the hydro moving fine.
I've had no problems with the tractor except for a couple hydraulic leaks at the newly installed 3rd valve for FEL grapple fittings. Tightened them up and away I went.
The only other thing I've noticed is that when in use 2 out of 10 times or so, I've had a warning light come on about HIGH OIL TEMP. Typically, when that happens I had been doing a lot of back and forth FEL work pulling trees and/or fences. So both transmission and FEL hydraulics were being relatively heavily used. But, I'd let it set for a while at idle, and the light would go off and away I went. I've insured there was adequate hydraulic oil. And honestly, I've added 3gal since I have had it. I see no leak except for when the hydraulics were leaking. I really don't think they could have lost 3 gal worth, but the first time, it was spraying out of the fitting pretty strongly for a few minutes. But, I've checked everything over and can't see a leak. Sight glass shows barely touching the top glass.
I was given the option, at purchase, to purchase an extended warranty. I can get it up to 5000hr/5 years with a $250 deductible. Cost ranges from $1399 for 1500/3yr to $4776 for 5000/5yr. The current warranty is good through next spring, March. There is also a Powertrain warranty which is less expensive 72mo/5000 @ $3820.
Given I've never owned a tractor before... at least one with a warranty, I don't know the utility of purchasing one in this instance. I'm not typically an 'extended warranty' kind of guy, but then again...
I'm using the tractor pretty heavily at this point. And will for the next couple years, but then, it will essentially be light work and mowing from then on.
What are your thoughts on getting the warranty at some level given these parameters? I don't know what typically goes down on these tractors nor do I know the typical cost for repairs. But $4776 seems like it could fix a lot of things... should they occur.
