Optima for Class two
   / Optima for Class two #11
Radiator Warranty Replacement
I had this problem on my Class III Boomer and got my radiator replaced under warranty. The link above has pictures of my damage. I hope you get yours done under warranty too. I haven't had any problems since my "fix." /forums/images/graemlins/cool.gif /forums/images/graemlins/grin.gif
   / Optima for Class two #12
Copies from NH Dealer Technical Concerns Web Site
Series TC SERIES TRACTOR CLASS 3
Group Electrical systems - 55
Summary Description BATTERY BOILING OVER
Symptoms Battery boils over
Excessive corrosion of front end components from battery electrolyte emitting from battery vents.
Causes 1. Alternator is overcharging battery.
2. Battery is overfilled with electrolyte.
3. Battery composition
Solutions 1. Connect a charging system tester to check alternator output. Start the engine and operate at 1200 - 1500 ERPM. When the charging rate has dropped to less than 10 amps, the system voltage will be stabilized. Stabilized voltage will be approximately 13.2V at 100 degrees F to 15.2 volts at 32 degrees F.. Average voltage at 70 degrees F. will be 14.2 volts. If the charging rate is less than 13.7 volts or more that 14.7 volts at moderate temperatures (70 degrees F.) there is a fault with the charging system. In a overcharging situation, be certain to check the battery ground attachment point at the front frame of the tractor for resistance. Remove the battery ground at this point and remove the paint to bare metal for a better connection.
2. Electrolyte level should be 1/8" to 1/4" below fill ring in each cell. Due to overfilling, temperature and vibration the electrolyte may vent out of the fill caps, onto the top of the battery. If necessary drain electrolyte from the battery until it is at the proper fill level. Wash the battery with a water and baking soda solution to remove any excess acid.. Clean and/or replace any tractor parts that were exposed to electrolyte. Check alternator for proper output (max) 14.7 volts.
3. Batteries used on TC series tractors are an agricultural type (antimony charged and rated for rough service). Typically agriculture machinery use is seasonable and equipment may go for extended periods of time without being run and without the battery being charged. An antimony charged battery will maintain charge over longer periods of inactivity than standard automotive type batteries, however, agricultural type batteries (antimony charged) will however produce more corrosive/acid vapor. For units in continual use where periods of inactivity or rough usage/service is not a concern consider a maintenance free automotive battery.
   / Optima for Class two #13
I picked my TC45D up today after the warranty repair. They replaced loads of parts including radiator, hydraulic hoses, battery cables, hood latch, battery platform, etc. My only gripe is I gave them the part number for the Optima battery and told them I would pay for the battery. How does $160.00 sound for a battery? I guessed over $100 but not $60 over. I just bought 2 Optima batteries from Summit Racing for $86.00 each delivered. My mistake, I should have supplied them the battery. I also had fluid and filter changes with the total bill over $727. Now I know why I do most of my own work.
   / Optima for Class two #14
727.00 For a service? wow? We run about 200.00-250.00 on a service for a class 3 that really seems extreme to me.
   / Optima for Class two #15
$727.00-What could they have done for that much money,especially on a newer tractor. I would go over that one line by line.Thats just too much green /forums/images/graemlins/shocked.gif
   / Optima for Class two #16
<font color="blue"> 727.00 For a service? wow? We run about 200.00-250.00 on a service for a class 3 that really seems extreme to me. </font>
Even if that included a new battery, if would still be completely out of line.
   / Optima for Class two #17
I agree with Grainger and the rest. Get a itemized bill and go over each and every charge. Check the hour charges and if you have a question ask for the standard charge for the work and see if it's close. If they were going to have to replace the battery under warranty you should only be charged the difference between the replacement and the Optima.
It almost sounds as if you got charged for the warranty work too.
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2023 Sundowner Rancher Express 24FT Livestock Trailer - All-Aluminum Stock Hauler (A55302)
2023 Sundowner...
2015 JOHN DEERE 35G EXCAVATOR (A52707)
2015 JOHN DEERE...
DRAFTING TABLE, METAL MOTOR STAND (A58374)
DRAFTING TABLE...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2013 Ford F-150...
5PC. WICKER SET (A58374)
5PC. WICKER SET...
