Opinions, please....
/ Opinions, please.... #11
I like the email idea. I think I'd had just said "wow, that's a lot of things going into one outlet!" and let it go at that. But emailing the guy is probably better, no sense embarassing him in front of his wife. Your lucky, few of my relatives invite me over, and when I hear from them, they usually have a number in mind.
Btw, missed ya on the Good Morning thread. Nobody postwhores like you!!!
/ Opinions, please.... #12
So you suggest he should have pulled the gear away from the wall and tallied up the watts for each plugged in item? And what about any open receptacles at the end of those cheapie indoor extension cords? Just assume those would never be used? What happens if (and it's a big if) they also plug a space heater in that same rats nest when it gets cold?
Not everyone is a master electrician, a well versed DYI or has a modicum of common sense.
"About 3,300 residential fires originate in extension cords each year, killing 50 people and injuring about 270 others. - See more at:
Fire-Related Statistics - ESFi :: Electrical Safety Foundation International
Oh and nice name calling...class act for sure.
"You can't fix stupid"
Did you remind them to wear their seat belts? OH! If they would wear a helmet while they drive it would be much safer. You might suggest it.
Not everyone is a master electrician, a well versed DYI or has a modicum of common sense. [end quote] which describes your credentials?
/ Opinions, please.... #13
OK...very distant relations, you hardly know them.
While there, you could have added up all the loads and seen if there was a real problem.
Now, it seems that the only approach would be to provide an actual help/solution.
What about purchasing two multi outlets which have individual circuit breakers...the sum of which is 15 amps or less and 14 outlets or more...under the assumption that this is a reasonably modern home with 15 amp breakers. Now, send them the note as discussed by others, along with a thank you gift of couple of multi outlets...or 3 if you think that is what is needed for safety. Telling them you noticed the problem and wanted to help them organize the wiring tangle. Maybe include some zip ties for all the cords.
This is a win win path. The young couple get advised by a distant relative of some of the hazards they may not be aware of. Assuming they NEED all those appliances in that location, an overload on one of the multi plugs will pop its breaker BEFORE a TRUE overload occurs on the house wiring. And, they get a warm feeling for their distant relative. You can live with yourself. Call it an early xmas present...or belated wedding gift...or whatever...
I always think it is better to solve a problem rather than lecture, become "holier than thou", or a pest......whenever it is possible to do so.
Who knows...perhaps your generosity will become a family legend, retold at family gatherings, and the lesson of proper electrical outlet organization/use is spread near and far and your line prospers for years to come.:thumbsup:
/ Opinions, please.... #14
Alright, you have the load calculator, gift cards and high-speed Internet connection for email ........ problem solved :confused2:
This is really simple. Should you have said something? The answer to that is in this question.
What will you say to yourself if you read the family died in a house fire this evening?
/ Opinions, please.... #15
What could be said
"Wow, that's a busy little outlet you have here!"
The entire message....On you!
/ Opinions, please.... #16
A mention of a recent fire near you (Google fires in your area and you will find one) and the cause (overloaded extension cord) give details to the individual and suggest a different arrangement.
Here I did it for you.
There is a bunch.
michigan fire extension cord - Bing
Appreciate all the responses...maybe I should supply some facts: House I saw the situation in is an old 2 story farmhouse with a Michigan basement and 100 amp fused main panel. As for the safety factor...my GF lost her favorite cousin and her husband in a home fire late last year and it's suspected overloaded wiring was the cause...
I am considering offering to correct the situation for the couple but it's a 2.5 hour drive one way....
/ Opinions, please.... #18
Well, that changes my original "not your business" response.
I would then send them the multi breaker extension box mentioned above with the story of your GF's cousin and state that you'd hate to see that happen to them.
/ Opinions, please.... #19
Being a do-it-yourselfer I hooked up our first gas dryer to a plastic vent tube not realizing I had no idea it was against code to do so AND dangerous. This in a new home.
8 years later the appliance repairman comes by to fix another problem and noticed it. He simply took it apart and told me what a fire hazard it was.
I was happy he fixed it with the proper metal ducting.
Fred, still here and didn't burn up in my sleep!
/ Opinions, please.... #20
OK...well, things are never simple, are they
Old...as in fuses, not circuit breakers. And, wiring throughout the house is likely of old type, poor insulation, perhaps of a small gauge. Thus problem could be anywhere , actually, that a high amperage device might be plugged in.
Applause to you for your concern and agonizing about what to do.
So, it now appears that the options are , in order of increasing expense
Educate the couple about the problem
insure fire alarms are installed in the house
assure that the immediate rats nest of cords is resolved and not pulling excessive amps
install a modern circuit breaker main service
replace wire/rewire entire house
I'm hoping that the couple are technically savvy and trainable so they can do some of the work themselves and live in the house in a way that avoids exposing the problem in a catastrophic way.
A "complete" solution would certainly be way expensive....even including your personal time and travel expense to pay them another visit.
But, at the root is the question of what money is for and what values and decisions a person makes in their life.....you can find these questions embedded in just about every TBN post/thread.
Thanks for sharing your concern with the TBN community...it puts a spotlight on the complexity and difficulty of being in "community" with others, be it at short or long distance, a close family member or distant, and how we interact to maintain pleasant and safe society. The tensions that make us human.
A personal story....my cousin visited the other day to see our fields of spring flowers...whole blankets of bluebonnets and indian paint brush...blues and reds spread across the pasture among the green of spring. Seeing our very friendly cat, she asked if he was micro-chipped ...nope, he roams 200 acres at will, avoids coyotes and hawks..so far..been with us 8yrs or so. She, being from the big city where apparently cats get lost, perhaps stolen, she believes every pet should be micro-chipped. She offered to pay to have ours chipped. I dunno. ..there are so many things I "should" do and have trouble getting around to...chipping the cat seems to be near the bottom of the list to me, but it's super important to her....
2017 Ford F-150 Ext. Cab Pickup Truck (A60352)
2017 Ford F-150...
2020 DRAGON ESP...
IRTPL 10,000 LBS TWO POST LIFT (A58214)
IRTPL 10,000 LBS...
2020 FORD F-550 CAB AND CHASSIS (A60736)
2020 FORD F-550...
2013 POLAR TANK 8,500 GAL ALUMINUM TRAILER (A60736)
2013 POLAR TANK...
Kubota LX2620 (A53317)
