Buying Advice Opinions on YM2000
   / Opinions on YM2000
Thanks California. I started by looking for tractors with loaders. I wasn't able to find any good ones in my price range ($5k). That's when I started looking at ones without loaders and figured I could add one later. Looking at your pictures makes me really want to get one with a loader.
   / Opinions on YM2000 #12
This is a add I seen. I would ask about it and possible loader.
TRACTOR
   / Opinions on YM2000 #13
I have done more since I added the loader than I ever did without the loader... There is always a use for loader.. It beats the **** out of a wheel barrow !!
   / Opinions on YM2000 #14
This may be a good buy!
For sale $4,800Ideal 31041, GA, United States - 5 days ago on gocounty.com
2014 Kubota L3200 4wd hst Trans W/Kubota la524 Quick Detach Loader & Ansung usa Quick Detach bk976 Backhoe for $4800. Tractor comes with lift arms for 3pt. implements when backhoe is taken off. Tractor is in (Excellent/New Condition) only 20hrs. I have owned for a year, selling because I upgraded to a larger tractor. Has warranty until 4/...
   / Opinions on YM2000 #15
If all you are going to do is prep a garden and mow, you might be well ahead to buy a larger 2wd machine, even an older gasoline tractor, with a mower.
I have the domestic model of the YM2000, the YM240, with loader, in both 2 and 4 wheel drive form. As California said, it is essentially the transition point between where a smaller tractor will do useful work without being 4 wheel drive. The 4 wheel drive definitely adds capability in some circumstances; for general lifting and moving of materials it is unnecessary.
The loader adds significant bulkiness and weight when mowing or working in tight places; if your 10 acres is fairly open, it won't be relevant. For gardening, you may consider asking around to see what others successfully do in your area. The combinations are typically to use a PTO tiller to prep the garden bed, or some combination of disk harrow, turning plow, and/or cultivator/bedder. For me the tillers actually process the soil too much for most gardening purposes (with some exceptions) for what I do, but others use them very happily. I don't think there is a single correct answer, but that local circumstances, conditions, and end goals all affect what tools are optimal.
You may really benefit by investing a few hundred dollars renting some various sized equipment, if there are rental agencies nearby, to see what works (and doesn't) for your purposes, on your property. As was mentioned, factors like the ability to put the machine on a trailer and safely transport it, to do maintenance yourself, or have a mechanic do it on your property, or whatever other things may influence your selection are important to consider too.
There is a Ford 600 ad in your area, a couple months old, with mower, plow, disk, scraper, middle buster etc, delivered, for 5500. There's a Kioti with loader for 7500, and a Massey 180, which is a LOT of tractor, and would run anything, for 4500. There's a well-priced Mitsubishi 4wd machine, and a Kubota tractor too. Be careful chasing a price point: typically the expense to bring something priced cheaply into good condition (tires, radiator/engine rebuild, or any "hard parts") is more than it would cost to buy one in good shape. You might be better served to rent or contract your jobs for a bit while you accrue more liquidity, so you can buy something ideal.
I would suggest making a list of must haves and like to haves. If you can't make a solid, defensible list, rent or hire some, first.
   / Opinions on YM2000 #16
$4800 for that...thats one of those scams. Call on it and I bet they tell you its packaged up and can't be seen but pay with google wallet or paypal and you have a 30 day refhn guarantee or something and can return it no cost. There use to always be a scam with a JD that ran something like that. They always have every implement possible with them and like 200 hours.
   / Opinions on YM2000 #17
I am not sire what soaking costs now but just a few years ago they were only like $4300 for a ym2000 reconditioned with 1 year warenty from frederick. I know they probably are more today but not that much more.??
Steve is a good guy just give him a call. He will have uses models from trades every now n then...see what he has. Worth a call.
   / Opinions on YM2000 #18
Long ago I inquired on one of those on Ebay, advertised as local and from a seller with a few years of good feedback. They said it was now in Portugal but would be shipped back free ... I dug a little deeper and found the seller's feedback was all based on knitting materials, largest sale under $30. Clearly someone had hacked her account.
   / Opinions on YM2000 #19
always scammers on craigslist. if it looks too good to be true, it's a scam. I sold a finish mower and a camper on CL, both times contacted by scammers wanting to send me a cashiers check for full price and a representative would pick it up. when I told them cash only I did not hear from them again.
   / Opinions on YM2000 #20
Ran across one of these locally for cheap. Thinking about pulling the trigger on it
I regularly mow about 2 acres and bush hog another 2. Lots of hills on the bush hogging. Would a yanmar 2000 be better instead of a zero turn for all the mowing? I could see this tractor paired with a 4 ft finish mower....
Also, what would be reasonable for pricing on this model in todays market? Its definitely the 2wd model, unsure of hours but I hear its mostly irrelevant with these
1990 Ford Mustang GT (A57148)
1990 Ford Mustang...
HELI 25 STRAIGHT MAST FORKLIFT (A52709)
HELI 25 STRAIGHT...
(1) HD 20ft Free Standing Corral Panel with Feed Bunk (A57453)
(1) HD 20ft Free...
2022 Chevrolet Tahoe SUV (A56859)
2022 Chevrolet...
1790 (A58375)
1790 (A58375)
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
