Opinions on what tractor will fit me best??
   / Opinions on what tractor will fit me best?? #1
Robertpsu
Holland, NJ
Kubota L3800
New to the forum, been more of a spectator then a poster. In any event, my wife and I just purchased 29 acres, consisting of 3-4 acres of lawn (buying a zero-turn mower), 5-6 acres of pasture/field, 10 acres of tillable land, and 10 acres of woods (on a hill). Currently the 10 acres is hay farmed, land is leased to a local farmer. As for the rest, that will be on me, at least for the rest of the year or two. I plan on maintaining and thinning out the woods, removing an additional 1-2 acres of woods to enlarge the lower field (farmed field), have to brush hog the pasture once a month or so, maintain and plow the 1,500' driveway (3/4 of driveway is crushed stone), till and maintain 1/4 acre vegetable garden (plan on enlarging it over the next few years, possibly up to a full acre). Also, they currently have two additional 1/4 acre gardens, one of grapes and one of peach and apple trees. In the future, I would eventually want to farm the lower field, whether it be hay, corn, or vegetable So my question is: will the 40Twenty series (4520 or 4720) do what I do now and in the future or should I just buy a 5M Series tractor. If 5M, what size? In addition, I am also a builder and do some landscape construction work, so I plan on using this for work occasionally.
Here are the attachments I was thinking of getting: loader, backhoe??, tiller, brush hog, rock bucket w/grapple, box blade or rear blade?, pallet forks, post hole digger, pto spreader and sprayer. Am I missing anything?
Thanks in advance!
Rob
   / Opinions on what tractor will fit me best?? #2
Welcome to TBN Rob. Please see my interspersed comments, and I'm certain those with more experience than I will add their opinions too.
That's quite a variety of uses on 29-acres of land. You might consider a John Deere "X" series garden tractor as an alternative to the zero turn mower as the garden tractor will be more versatile than than a ZTR for your future food plot and lawn. I would think a regular tractor is going to be too big for the food plot and lawn sizes you are contemplating.
I think the the 4520 or 4720 will be more than adequate for your needs. I assume you're looking at a cabbed version. I'm not sure you can get a hydrostatic transmission with the 5M tractor. A HST will be your only choice with a cabbed 4x20. In any case, I'd get a cab as a 1,500' foot driveway is going to be miserable to remove snow using an open station tractor.
Here are the attachments I was thinking of getting: loader DEFINITELY!, backhoe?? Maybe if you have tons of work for it, otherwise look into renting a mini excavator for backhoe type jobs, tiller For the "X" series, brush hog Yep, 1-foot of width for every 5-PTO HP is a guideline, rock bucket w/grapple, box blade or rear blade?, pallet forks Yep, post hole digger Rent a skidsteer with PHD, I have a bias against 3PH PHD's, pto spreader and sprayer. Am I missing anything? Snowblower?
Attachments listed without a comment are because I have no real opinion on. I have a rear blade; but not a box blade so I can't comment on which is better. I have a sprayer, and they are useful; but can also be a PITA. I don't have a spreader.
You might try and buy the two units together and see if the dealer will give you a bigger discount. Of course that assumes you're buying new. You East Coast boys have far more choice of used equipment than us Colorado people do.
Thanks in advance!
Rob
Thanks for getting back to me. I've been spinning my head trying to figure out what I'm gonna do. I kinda wanted to spend my money once and be done with it. I was looking at the 4520 and then started looking at the M series. I was thinking if I ever wanted to hay the field myself, would it be something that can be done with the 4520 or the 4720? As for the lawn, I'm kinda stuck on the zero turn as I'm not a big fan of the riding mowers as I have one now. I know how much quicker I can get it done with a zero turn
   / Opinions on what tractor will fit me best?? #4
I have no clue on haying, so I can't be of any help there. I think a 4x20 will be more nimble than a 5000 series; but once again, that's speculation on my part.
If your lawn tractor is a BBM (Big Box Mart) type; the "X" series, especially the 500 and 700 series are far more advanced than any 100 series Deere lawn tractor ever will be. The other reason I suggested an "X" series is that you can add implements to it for use where the big main tractor is too big to be used effectively. A ZTR is a single use machine.
   / Opinions on what tractor will fit me best?? #5
Dilemma---requirements-----decision ---- shopping--- purchase?.
Sounds like you have everything well in hand!:thumbsup::thumbsup:
If using the tractor in construction type situations consider going to one that is more backhoe designed as the chances are it will get used.:D
   / Opinions on what tractor will fit me best?? #6
When comparing the 4520 / 4720 Cab models a while back it seemed to me a 5083E could be purchased for not that much more. A BH is available as would all the other toys you mention. While not meant to be a lawn mower, it might do all the other things you mention as well or better than the 4x20 machines.
The M series you mention, while having more bells & whistles comes in about $10K higher than the E series.
As a bonus, in some jurisdictions, it may qualify as a "farm tractor" based on PTO HP and be tax exempt.
   / Opinions on what tractor will fit me best?? #7
i have a 4510 with a loader and a 72"mmm and i can tell you they are good tractors.it is a little oversized for mowing my 3 acers of lawn and a little undersized for working my land. my land has alot of rocks and pulling a 3 bottom is allmost a no go.and when the loader on and you get a good load in the bucket you need to either have the tires loaded or weights or both cause the rear is light.
   / Opinions on what tractor will fit me best?? #8
I would suspect a 4520 or 4720 would be a good fit for your uses. I use my 110tlb, 4520 and x749 for my landscape work and the hydro transmission are great for this purpose. Having the cabs is very worthwhile too imo.
For landscape work I get lots of use out of the landplanes and boxblades for initial shaping and contouring. Landscape rakes and pine straw rakes are very useful for cleanup work and covering seeds. Might want a roller for the grass seed for new lawn areas too.
I use the x749 for close quarters work and it has really saved me money on labor this year by reducing the amount of handwork to a minimum.
You should be able to run a small square baler with a 4520 or 4720 without problems. I would question whether it is profitable on such a small acreage and would pass on this myself.
   / Opinions on what tractor will fit me best?? #9
Thanks in advance!
Rob
smaller tractor with all the bells and whistles. or a larger tractor and just the basics....
for you, i would say smaller tractor with all the bells and whistles. and lease out the farm land.
if you are going to do the farming yourself. then i would be going for the larger tractor with just the basics. the farming takes larger tractors, not just in the HP but the weight department as well. if you lease the land out. then you are more likely getting a farmer. that has already invested in the bigger machinery that can get things done for farming.
80 acres here, and i lease the farmed area out. so much easier. at one time had cows, and larger tractors, but man, that was overkill. any more you need more and more acres, to help offset the larger sized tractor costs to make things worth while.
not needing such a large tractor, lets you get get a smaller tractor with all the bells and whistles. that a larger tractor with just the basics would cost.
and those bells and whistles can make life much more enjoyable and easier. granted some tasks will take longer. but the bells and whistles can help make up for things.
CAB, winter sucks, more so the cold wind!
good tranmission with quick easy changing of gears with a button, without need of every using foot clutch with exception of perhaps initially starting tractor. manual foot clutch. never again it really does take a good amount of time to push in foot clutch and change gears, vs being able to step on a different peddle or push a button to change gears or move forward or backwards. and for a multi use tractor. being able to quickly change gears and forward and backwards. it is one of them non stop things you do.
extra work lights on front and rear. really do help and extends hours you can use the tractor a good amount. more so in winter to plow drive.
TNT (top n tilt) for the 3 point hitch. if your drive has a variety of angles and curves. to help with water drainage. TNT can really help by just moving a lever in the cab. vs getting out and manually adjusting which way the implement angles/leans for next portion of the drive way.
backhoe, it is well worth it. more so if you get a tractor, that allows you to pull lever to twist seat around and begin user the backhoe. i am not a large fan of having to get off tractor, and then get on backhoe seat. to much time is lost. and after half day to a full day of work, you have walked a few miles between tractor seat and backhoe seat.
for me backhoe comes into play with, getting my rear unstuck when i went to far out into the mud, removing tree stumps, putting in culverts, putting in electrical, gas, water, internet, telephone lines, putting in a sepetic tank and drainage fields. moving stuff in and out of a pickup truck. ya FEL (front end loader) can work, but the backhoe on 555c has a better distance i can work with, without fear i may accidentally run something right into side of pickup truck. because i can not see side of truck.
if ya get the smaller tractor, the bells and whistles beside the backhoe itself, would be a hyd thumb for the backhoe. allowing you to grab a hold of rocks and small trees, to pulling posts from seat of your tractor.
at moment all i have to work with is FEL (front end loader) to remove mud holes. and move little bit of rock around. once i trade out this large 555c TLB, it will be back to a rear blade and box blade. not one or other but both. rear blade is nice to remove snow, when it is only a couple inches deep, and helps me to move rock back onto the drive way. and also helps me to move dirt back onto the dirt paths were ruts were. the box blade helps me get a better smooth grade. and helps me break up the gravel. and in some areas will help me to loosen the top layer of soil and rock. to smooth out bumps and holes.
pallet forks, it would be nice to have them. but i honestly do not need to remove pallets off of a truck. or anything of the like. if you were in landscaping buisness. and wanting to move pallets off your truck / trailer to some place you are working at. then pallet forks might be a better option. but if you are wantting to make a large platform out on the front bucket to hold tree limbs, and brush. you can create pallets forks out of some 2x4's and some ratchet straps. and a piece of plywood.
3pt post hole digger. worth it. the only down side is if you have hard ground. i do in various places around here. i have a hard time getting a PHD to go through that hard dirt. there are kits to add a cylinder for "down pressure" for a PHD. if going for smaller tractor with bells and whistles this may be one of them whistles.
PTO sprayer worth it. more so if the pasture / woods have stuff you do not want and want to spray it to get rid of it. though on demand water pump sprayer maybe more worth it.
you say tiller, but if you are working that much of a veg garden. i would say plow and disc, and harrow. do not get me wrong tillers are nice. and if used on a buisness can allow you to back right up to something and drop tiller down and get going. vs a plow / disc / chain harrow. i am bias. when dad had riding lawn mower, (garden size riding lawn mower) with tiller. it was painfully slow. there always would be some sort of large rock or brick or twin or rope even weeds that would wrap up around the tines of the tiller and you would be out there with a razor blade, various size flat head screw drivers, needle nose pliers, hammers. to remove the stuff from the tines. granted the tiller being on the tractor was a large improvement over a walk behind tiller. the 2 bottom plow, disc and harrow for the allis Chalmers tractor to me is an improvement. over the tiller for large size doings. ya i gotta hook up different implements. but i am no longer removing crud from the tines on the tiller. personally like the 2 bottom plow. it lets me pull up a bunch of dirt into a row, for say potatoes, or melons. vs getting out there with a walk behind tiller and metal rakes.
again tiller is nice, more so if you have landscaping business. were being able to back up to stuff and drop tiller down. and get that much closer to stuff does help.
with all the implements you listed. i would imagine bells and whistles would be Quick attachment. for both 3pt hitch and FEL. so it is easier to switch to different things.
bells and whistles, would be a "winch" to help pull stuff up and out of the woods. to a wood chipper.
rock bucket with grappel. do not know why you want or need the rock bucket. or less you live some place were there are a lot of rocks in the soil. or wanting to move large size rocks / bolders. or you are wanting to rock bucket with grapple to act like teeth to grab and rip out various bushes and small trees on your property. prefer backhoe with thumb for that. granted backhoe does not have as much power compared to FEL when lifting / pulling stuff up like that. though prefer backhoe maneuverability to grab ahold of just what i want. vs trying to angle tractor in multi different directions to get the FEL to go were i want it to. and if something is stubborn i just take a quick bucket full of dirt or like and bye bye i go.
a "boom" that goes on the FEL might be nice, to help raise trusses, on a low building.
pallet forks, might be nice to raise say a pallet of shingles up to the roof, and then unload the shingles manually onto the roof of a house. or perhaps move a pallet of lumber or bricks off a trailer and/or truck. onto the construction site.
PTO generator can be nice, if you are a house builder. and do not have temporary power hook up yet. or working out in pasture / woods. and need some sort of power equipment. been there done that. or live out in middle of no were and power goes out a generator comes in handy. at moment just move the little 3000watt generator around.
bucket hooks, most tractors do not come with hooks on the buckets so you can easily attach chains.
loaded tires, for more rear weight for better traction, and help stabilize tractor some on hills.
Just wanted to thank everyone for your responses. I've decided that I am going to go with a 4720 rather then a 5M tractor. After thinking about it and reading everything I can get my hands on. The versatility, size, power, HST and available attachments of the 4000 series and the fact that it will be much easier to trailer, makes it the better tractor for me.
As for attachments, I'm going to get the loader, backhoe, tiller, box blade, landscape rake, pallet forks, brush cutter, post hole digger, spreader, sprayer, TNT (thanks boggen) and the rock bucket with grapple (upper fields are rocky, so I figured I could knock out two birds with one stone and get the grapple add-on to clear brush and move logs.
Does anyone have the drop down blade for the landscape rake? If so, how does it work?
Thanks again!
Rob
GODWIN CD150M DRI PRIME PORTABLE PUMP (A51406)
GODWIN CD150M DRI...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket (A53472)
Kubota 24in Quick...
UNUSED RAYTREE RMSC78-78" SOIL CONDITIONER (A51248)
UNUSED RAYTREE...
2013 ISUZU NRR 20FT FLATBED TRUCK (A52576)
2013 ISUZU NRR...
36in Excavator Bucket (A51573)
36in Excavator...
2017 CASE IH 580 QUADTRAC ARTICULATING TRACTOR (A51247)
2017 CASE IH 580...
