Opinions on the Kubota L5030? 2nd try at posting..
   / Opinions on the Kubota L5030? 2nd try at posting.. #1
Mdub
Washington State
well, this will be VERY short since I already did a long post and now there's a "problem locating that post" /forums/images/graemlins/frown.gif
What are your "tractor expert" opinions on the Kubota L5030 with loader?
   / Opinions on the Kubota L5030? 2nd try at posting.. #2
You've only made 2 posts as of now, finding your first one is very easy. Click Here
Okay so my other post ended up in the Kubota forum /forums/images/graemlins/blush.gif Thanks!
   / Opinions on the Kubota L5030? 2nd try at posting.. #4
I've got it's baby brother (L4330 - LA853). LOVE IT!
   / Opinions on the Kubota L5030? 2nd try at posting.. #5
Same here. 4330, 863 loader, GST transmission.
One of the interesting diffferences between it and every other diesel I've had is when its running inside the barn, you can't really smell it.
Another thing is the loader comes off and on so fast, there is no reason to bush hog with it on. More maneuverable and less "collateral damage".
Also that loader moves up and down fairly fast at idle speed. You don't need to rev up the engine.
   / Opinions on the Kubota L5030? 2nd try at posting.. #6
JMC, isn't that the truth. The L3830 I have I have seems to burn so clean that running it in the shop is a non issue. My neighbor has a JD 790 that stinks at start up to shut down. I use it frequently because he has always got at least one of my implements attached. It works out well. Right now he has the post hole digger on and I tell him to keep it on since it's such a pain to put on. The cylce times on the LA 723 and LA 853 are second to none. Quick, strong and sturdy. The L5030 has basically the same diesel as my L48 had. My L3830 has the same engine as the L5030 less one cylinder. I still say the Kubota HST is second to none. Other then bigger tires and engine, the L5030 is very similar to the L4630 and L4330.
2019 Chevrolet Tahoe LT SUV (A51694)
2019 Chevrolet...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
2025 New/Unused Wolverine Pallet Fork Frame with Forks (A51573)
2025 New/Unused...
2008 Hino 268 Truck, VIN # 5PVNJ8JV582S51513 (A51572)
2008 Hino 268...
2006 INTERNATIONAL 7600 T/A DUMP TRUCK (A51406)
2006 INTERNATIONAL...
2018 Ford F-550 Flat Bed Truck, VIN # 1FDUF5GTXJEC35552 (A51572)
2018 Ford F-550...
