Opinions on New Holland Workmaster 60
   / Opinions on New Holland Workmaster 60 #1
City Farmer
Platinum Member
Chesterfield, Mi
Ford 3000, 4400 & 4500TLB Case 830 Case 350 dozer
Hi guys. I've been thinking about selling all my older tractors and picking up a new one. I'm building a new house/barn this year on 24acres, 16 is open & 8 is wooded. As much as I like working (on my schedule) on the old iron, I don't want to deal with break downs in the middle of this project.
I was looking at the NH Workmaster 60. It seems to be exactly what I'm looking for, 50pto HP, 4x4, the loader lifts 2700lbs and is detachable. I drove it around a little bit and I really like the shuttle shift. I should be getting a quote today with the 621 loader and 3 remotes, I wanted 4 but he said they don't offer 4. I'm probably daydreaming but If quote comes in the mid to low $20's, I think I'll buy it.
What can you guys tell me about this machine, the good & bad?
   / Opinions on New Holland Workmaster 60 #2
Mine was delivered last Thursday. I put 10 hours on it over the weekend testing it out on various chores and I'm pleased so far.
While lifting some old wooden posts out of the ground the 621 FEL was able to get the back end off the ground. Tires are filled, but I'm adding some weights to the rear wheels this weekend. image.jpeg
   / Opinions on New Holland Workmaster 60 #3
While lifting some old wooden posts out of the ground the 621 FEL was able to get the back end off the ground. Tires are filled, but I'm adding some weights to the rear wheels this weekend. View attachment 461848
Nice tractor :)
Adding weight to the 3pt lift will do your front axle a favor compared with wheel weights.
   / Opinions on New Holland Workmaster 60 #4
Don't forget to look at LS for a better price on the same tractor. Look at the XU series if you think you need that much power.
I don't think that's true anymore. I just got off the phone with a LS sales rep a few minutes ago. He gave me a quote for the XU6158 with 2 remotes and he's $6500 more than the NH dealer on the WM60. I'm not sure about the LS but the WM is coming with loaded rear tires.
   / Opinions on New Holland Workmaster 60 #6
Those aren't the same machines.
   / Opinions on New Holland Workmaster 60 #7
The Workmaster would be more comparable to the LS K series.
   / Opinions on New Holland Workmaster 60 #10
There are small WorkMasters that share some LS parts, the big ones are totally different tractors. Even the small ones are getting more different all the time.
378813 (A51573)
378813 (A51573)
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2013 International DuraStar 4400 Altec AM547 50FT Material Handling Insulated Forestry Bucket Truck (A51692)
2013 International...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2006 Utility 3000R 53ft T/A Reefer Trailer (A51694)
2006 Utility 3000R...
2025 New/Unused Wolverine Pallet Fork Frame with Forks (A51573)
2025 New/Unused...
