opinions of backpack sprayers
   / opinions of backpack sprayers #31
What is everyone using to kill brush along fencelines? Have used Roundup, but it costs a fortune to use. Anything work as well or better and is easier on the wallet?:eek:
   / opinions of backpack sprayers #32
We've gone to a generic round-up that runs about 1/2 the price in a concentrate form. Seems to work as well for us. You find it under many different names. You want to look for the active ingredient glyphosate at 41%. That is pretty much what round-ups heavy duty concentrate is. When you say "brush" do you mean saplings and such? There are other treatments for woody types of vegetation. Round-up and its off shoots target grassy/leafy vegetation better.
MarkV
   / opinions of backpack sprayers #33
Yes, the brush appears to mostly multifora rose, tree saplings, and some honeysuckle .
   / opinions of backpack sprayers #34
Last year when I looked at this, the real Roundup had a higher concentration of glyphosate. I got out my calculator in the co-op and decided that there was no real difference in price based on price vs. quantity and % glyphosate. For the same real cost, I went with the name brand.
YMMV, but with a calculator in every phone and the information right there on the label, it is easy to determine the best deal.
That's what I was afraid of. I have about a dozen fruit trees and attempted to use the backpack sprayer on them. Good grief my arms cramped up and about fell off from the pumping. :eek:
I switched to my Spray Doc and it was much better. I fill it, pump it up and spray half the tank before pumping it again. If they made something like that in a backpack model, I would probably buy it.
I've had terrible luck with the small tanks. I seem to go through a couple a year and my trees are now taller than they can spray. The other thing is that with the amount of oil spray needed per tree, I would have to fill the little tank much more often. I've not used a Spray Doc perhaps they are better.
It was between a metal hand-held tank or the backpack sprayer. I ordered a Stihl and hope that will last me many years.
   / opinions of backpack sprayers #37
Not on the same level as the Stihl or Solo but for the house here I bought a Stanley that my Sam's club has every year for $40. I am very careful when spraying loading etc. as I am uncomfortable about chemicals on my back but so far, knocking on wood, it has not leaked etc. (1 years use, probably 30 gallons) Might be another option to consider.
   / opinions of backpack sprayers #38
I've got a Solo. I'm going to buy a Stihl pretty soon. The Stihl is much better made as far as I can see just from looking at it. The Solo is OK. Just too much plastic. Since I can use another one I won't be buying another Solo.
   / opinions of backpack sprayers #39
Have a Stihl 5G20. Only issue I have had is during the hot weather the “O” ring gets dry and the felt bushing in the pump drys out also. Just keep a little oil on the pump shaft after using it. If either one drys out, it will not pressurize.
2000 Ditch Witch 3700DD Ride-On Trencher (A53421)
2000 Ditch Witch...
2007 Freightliner B2 School Bus (A55852)
2007 Freightliner...
CATERPILLAR 247B3 SKID STEER (A52707)
CATERPILLAR 247B3...
2009 IC Corporation PB105 School Bus (A55852)
2009 IC...
2011 SHOP BUILT FLARE STACK (A53843)
2011 SHOP BUILT...
2019 Ford Explorer (A55788)
2019 Ford Explorer...
