opinions of backpack sprayers
   / opinions of backpack sprayers #21
Sounds like that little green one, using a shoulder strap, is still the optimal solution. I have 4-5 similar (inherited from various family) in 1 and 2 gallon size. I think each needs re-pumping only a couple of times per fill. It's easy to bear down on the pump if you put it on the ground. I fill several, carry them out into the orchard, and try to work back to the cache just as I empty one.
I was reading here to see if a backpack version was better but now I'm not convinced. Sure, for a straight fence row. But circling back and picking up another out of the loader bucket works too. I am only applying Roundup to the occasional random Poison Oak (which makes later harvest difficult), not clearing all the grass around each tree which would probably require a small trailer rig.
Yes. I was thinking of mounting my tank type sprayer to a backpack frame. Then I wouldn't have to carry it in one hand. I have three of them. One is like the large one pictured in my last post. And I have two other smaller ones. I use one for spraying water proofing on my deck every year and the other is for weed killer only.
   / opinions of backpack sprayers #22
I don't know Moss...I had used one of those like what you are using. After using one of the backpacks, I won't go back to the tank and handle type, except for really small areas to spray. The backpack IS easier and you can carry more solution before refilling. Also, if you are left handed you can switch sides with the pump up handle. I recommend getting a backpack type. Solo may not be the best, (since I only know about that brand), possibly go with one of the others that the fellows recommended.
   / opinions of backpack sprayers #23
Just something to think about. My dad bought a wheeled cart used for carrying a golf bag at a garage sale and modified it to carry his sprayer. Seems to work pretty well for him.
   / opinions of backpack sprayers #24
Well I am now smacking my self in the forehead! :eek: That is just too simple! I will go to my local salvage shop. They always seem to have those carts back in the corner with the wood shaft golf clubs. Thanks! :)
   / opinions of backpack sprayers #25
Yeah. I had to switch the handle back and forth from side to side because I'd get arm cramps. I just wonder if my backpack sprayer is the proverbial piece of junk? :eek: I know if you give it a few pumps it will spray straight up about 25-30 feet but quickly lose pressure. You have to keep pumping. Maybe I will go to a dealer of the newer sprayers that are mentioned in this thread and test drive them with water this spring.
Thanks for the help! :)
   / opinions of backpack sprayers #27
... or just put a big comfortable golf bag strap on the little tank sprayer. That will be easier to set on the ground to pump back up, compared to a backpack frame.
   / opinions of backpack sprayers #28
Now you guys bring this up after I gave away a golf bag caddy. I have a different brand of backpack sprayer, and find it uncomfortable and heavy, plus the pumping is not fun.
What I would like to see is a 12v pump and battery to avoid having to pump. Could mount the whole thing to the golf bag caddy.
   / opinions of backpack sprayers #29
I have a Solo and an Echo...
Both have provided years of service...
The Solo has a plastic spray wand that can become distorted if I'm not careful when I put it in the back of the pick-up and I've learned to never lean forward with a full tank... the shoulder straps are very comfortable.
The Echo has a Brass Wand and it has been a trouper...
I've also riveted the shoulder strap adjustment to keep it where I need it... just less fumbling around.
I spray 60 to 80 gallons of mix a year.
   / opinions of backpack sprayers #30
Thanks. I'll look into that, too. ;)
2014 INTERNATIONAL MA025 BOX TRUCK (A56138)
2014 INTERNATIONAL...
2009 IC Corporation PB105 School Bus (A55852)
2009 IC...
2019 FORD F-650 SUPER DUTY BOX TRUCK (A51406)
2019 FORD F-650...
2017 FORD F250 SUPER DUTY EXT CAB SERVICE TRUCK (A53843)
2017 FORD F250...
2005 Kaufman Trailers Car Hauler Trailer (A53421)
2005 Kaufman...
