Opinions about york rake
/ Opinions about york rake #1
commander
2002 Kubota BX2200
Any thoughts about how large a york rake I can use with my BX2200?
Sorry about the double post
/ Opinions about york rake #3
Typically landscape rakes (york rakes) are fairly light so lifting shouldnt be a problem on your BX.
They also pull pretty easy since they arent really engaging in the ground like a plow of blade would.
That being said, you would be able to pull even a 8 footer and not have any problems.
The things you have to decide is how manuverable you want it to be. 8' would be sticking out pretty far each side. And if you only have 8' garage doors, it probabally isn't going to fit.
Another consideration is if you get one that is reversable, how narrow it needs to be to be able to reverse while on the 3PH. A 6'er may be close, but a 7' or 8' would definatally need taken off to reverse.
So it is really a matter of personal preference. The larger ones will pull just fine, and get the job done quicker, but at the inconviences I mentioned.
John Deere 7000 4R Planter (A66408)
John Deere 7000 4R...
New/Unused Quick Attach Backing/Mounting Plate (A65583)
New/Unused Quick...
2022 EZ-GO ELITE...
1984 Charles Machine Works S4A S/A Tilt Deck Trailer (A61573)
1984 Charles...
2025 Kubota L3902HST w/ Kubota LA526 loader - 1 hour and new financing
2025 Kubota...
Parker Gravity Wagon (A66285)
Parker Gravity...
