opiniones wanted on trailer jack
   / opiniones wanted on trailer jack #1
Soundguy
Old Timer
Central florida
RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
Ok.. so now I have my 24' gooseneck trailer. I'm assembling it's travel accessories. It's at this point I wonder what type of jack is best. In the past I've always used hi-lift style farm jacks around my place.. for tractors and my 16' bumperpull trailer.. etc.
RickB has been on me about getting a good 10 or 20 ton bottle jcak before I drop something heavy onmyself using the hi-lift. so I've been considering one.
opins here? it's got tires.. so I'm bound to get a flat.. so a jack will be needed.
hi lift or bottle?
thanks
soundguy
   / opiniones wanted on trailer jack #2
As long as the side of the trailer can stand the jack rash the highlift is my choice.
I keep one in my truck
Very rarely will it run out of stroke.
you don't have to lay under something to lift it.
Now if you have to "lift" over 5 tons or so the bottle is the only way and a pile of cribbing.
tom
   / opiniones wanted on trailer jack #3
I keep a 12 ton bottle jack in all 3 of my trucks. I got them at Menards for around $16 dollars. They have a little case but will leak some so I line it with paper towels. Also takes out the rattles.
Chris
   / opiniones wanted on trailer jack #4
I keep a 10 ton bottle jack in my 16 foot trailer tool box along with a few short pieces of 4x4 in case I need a little extra lift height.
   / opiniones wanted on trailer jack #5
A good bottle jack , jack stand and / or some blocks of oak or similar 4x4 , 6x6 is what I would use . Much safer and if sized right will lift most anything .
   / opiniones wanted on trailer jack #6
Good point on the wood. I keep pieces of 2x6 about 8" long in all my trucks for that need.
Chris
I'm fond of my hi lift for the reason someone else mentioned.. hard to run out of height on them.
I think I will go ahead and grab a bottle jack as well though.. they are cheap enough.
Already got plenty of cribbing with me... and I usually carry at least one jack stand when i road trip anyway..
thanks for the ideas guys
soundguy
   / opiniones wanted on trailer jack #8
On my 20' bumper pull I added flip down stands on the back to keep the back from dropping down while loading and unloading. With the stands down at the back I can lift the entire trailer off of the ground with the jack on the tongue. I would not want to try it with a heavy load on the trailer. But it works well for maintenance and would work on the road if necessary. If a front tire were flat it would be easy to use the tongue jack to lift the front tires off of the ground without need for the rear stands.
   / opiniones wanted on trailer jack #9
I carry a 20 ton bottle jack in my truck ever since the day I had my dump trailer loaded and picked up a nail in a tire. I stopped at a small town tire place and believe it or not they did not have a jack heavy enough to lift the trailer! Their air compressor would not go to 110 PSI to reinflate the tire fully either....
   / opiniones wanted on trailer jack #10
I picked up a small 6 ton bottle jack to put with mine. I also carry different size blocks (4x6x12 and 2x6x12, 5/4x6) with mine. with a highlift your likely to jack directly on the side of the trailer, so hight may be an issue. But i plan on useing my bottle jack under the axle which at most is about a foot off the ground. well within the range of a standard bottle jack even without any blocking. In addtion to jacking the axle itself i only have to move just a few inches as there is no spring/shackle/equalizer movement to deal with like you do when you jack the side of the trailer.
Either one would work, one may be a better choice than the other depending on conditions. if you have the room take both :thumbsup:
REYNOLDS 100 - 8 YARD PULL TYPE SCRAPER PAN WITH DRAWBAR (A52748)
REYNOLDS 100 - 8...
2018 MDB LV600 GREEN CLIMBER SLOPE MOWER (A51406)
2018 MDB LV600...
2018 COLOMBO TM LOT IDENTIFIER 171 (A53084)
2018 COLOMBO TM...
PALLET OF ARMSTRONG CEILING TILES (A51248)
PALLET OF...
UNUSED AGT AIR COMPRESSOR W/ 420CC MOTOR (A51248)
UNUSED AGT AIR...
2015 John Deere 544K Articulated Wheel Loader (A52377)
2015 John Deere...
