Opinion on a Lincoln easy-mig welder 140 wire
   / Opinion on a Lincoln easy-mig welder 140 wire #21
Story of my life! :drink:
I am sure you guys must already know that the guy who dies with the most tools WINS.
I am 78 now, and still gathering.
Problem for me is that I have two homes 1500 miles apart, so I have two (or more) of MANY things.
For the smaller doubles, I sometimes cannot find them....so.... then I wind up with three.
It sucks to get old, but I am happy to be still working on it.
   / Opinion on a Lincoln easy-mig welder 140 wire #22
I have a Hobart Handler 210. Its a good machine, no problems other that newbie issues of my own creation. I have done all of my welding on 120V with flux core wire and so far, its been serviceable, but not pretty. Really need to get a properly connected 220V socket in my garage. That and switching to MIG and adding gas will really help.
With that said, I have welded the 1/4 SSQA plate for my plow last year and the plow A frame angles and haven't had any strength of weld issues. So you can do the heavier stuff with 120V and flux core. But I'd never bet anyone's safety on it. Then again, I wouldn't weld anything that important anyway...
   / Opinion on a Lincoln easy-mig welder 140 wire #23
I have a hobart handler 140 ez, basically the same machine in what it can do. I've done some pretty serious jobs with it, although they took about 3 times longer than if I had just bought a proper machine because of the duty cycle. These little machines have there place because of their portability but if your going to be welding in your garage then this isnt a factor.
I would buy a better machine, one that you can grow into! For a beginner you need all the help you can get and a 220 machine with infinite adjustments on amperage and wire speed will not only be able to do more jobs but will leave you with much much better results.
Like I said, the only reason to get a 110 machine is if your going to be taking it with you on the go or repairing broken stuff in the field.
   / Opinion on a Lincoln easy-mig welder 140 wire #24
The small Lincoln machines are not any better quality than the higher end harbor freight or Hobart machines. I have the Hobart and its been solid. I would seriously consider buying the mig/tig that harbor freight has come out with recently if i was buying today. its $700. 200 amp, duel voltage and mig/tig. or, if you want mig only, they have the vulcan 170 duel voltage for $499. I saw a tear down of it vs the Lincoln equivalent and the Vulcan was as good or better in nearly ever respect. those are the list prices, always a 20 or 25% coupon to be had.
Just run an extension cord from the laundry room like I did, Your wife will love it!
   / Opinion on a Lincoln easy-mig welder 140 wire #25
Be aware that the box store Lincoln is not the same as a unit sold by the welding outlet. There's a reason for the higher price. They build to a price point for the consumer market same as other manufacturers.
   / Opinion on a Lincoln easy-mig welder 140 wire #26
Ha, I'm with you. I have 3 properties. One is 300 miles away and the other is 1600. I know what it's like to have to have multiples of everything from crescent wrenches to air compressors to chainsaws, power tools to Welders. Crap I have 6 lawn mowers.. Gearing up for liquidation !!
   / Opinion on a Lincoln easy-mig welder 140 wire #27
LOL I don't want two houses. I had two before I retired. I sold the one in the city and moved to the farm.
I don't want to go back to two. It's 2x the work.
Of course. the farm is 5x the work, but it's all in one place ! LOL
on another note.. I've been playing around with this everlast tig machine. It's kind of neat. It's far ahead of the old big bulky dedicated tig machine I used back in the 70's
   / Opinion on a Lincoln easy-mig welder 140 wire #28
Da--,...you got me there. I only have 4 lawn mowers.
But.....I do have 6 air compressors.
"Liquidation" ???
Never for me!
That will be an issue for my kids to deal with.
Until last month I too had 3 properties, all separated by many miles.
I finally sold the most distant (Canada) one.
   / Opinion on a Lincoln easy-mig welder 140 wire #29
I keep hearing that... Not disputing that but do we have any proof as to difference in actual model numbers instead of just "name" plastered on unit...
Love my HH 140 seems to be everything it is represented to be...
Dale
   / Opinion on a Lincoln easy-mig welder 140 wire #30
Dale
It used to be with Lincoln that the infinite controls were the welding supply model and the Tap settings like the old Lincoln Weld-Pak were the box store units. Not for sure if that is still the deal or not. They even threw in some Century by Lincoln in some of the box stores. Others like the older Hobart Handlers only had Taps so not sure there either but they were solid units too. At the end of the day all of the 115V welders put out about the same. Roughly 90 amps. I remember having a Lincoln SP100 115V. It had higher output with 030 hard wire than 023 or 035 cored wire. You just can't get enough volts to go through the 023 to run even the 115v units wide open. As always DC tongs on the ground tells all.
SELLICK S80J4E-2PS ROUGH TERRAIN FORKLIFT (A51242)
SELLICK S80J4E-2PS...
2013 VOLVO VNL860 TANDEM AXLE SLEEPER (A51219)
2013 VOLVO VNL860...
TRUCKING INFO (A50775)
2016 Toro Pro Force Towable Blower (A50324)
2016 Toro Pro...
Caterpillar Front Glass (A50854)
Caterpillar Front...
12 Ft Enclosed Trailer (A50324)
12 Ft Enclosed...
