Sodo
Elite Member
- Joined
- Apr 21, 2012
- Messages
- 3,292
- Location
- Cascade Mtns of WA state
- Tractor
- Kubota B-series & Mini Excavator
Consider strapping down a small load of 2x4s to your lumber rack.
There was a time when I cursed ratchet straps. Then a friend said "this is a really cool mechanism, you need to understand it" (fightin' words
). I like ratchet straps now. There are more than a few things you need to understand to be happy with using them. Its kind of surprising how many details there are, not surprising that people are frustrated by them.
1) How to thread it (the loose strap end comes out the top)
2) How to set the slot angle to pull tight first (before ratcheting)
3) What can you let the strap "touch" under tension? (ideally NOTHING, but sometimes it MUST touch the load)
4) Should you release it under full tension? Or back it off a few clicks first? (smaller units become a "one-use" if released under tension)
5) Occasional lubrication is essential. You will never learn how it works (or like them) if its simply "stuck".
The little orange ones (packs of 4 for $15$) can be damaged by releasing them under tension ONE time. Not surprising for an item you paid $4 for. Often a newbie will be trying to "learn" on a ratchet strap that he just destroyed. Thats no way to learn - it's damaged, the mechanism no longer works and now you can't can't possibly learn from it (unless you take the time to repair it). The 2" (yellow) ratchets are pretty tough and can survive release under tension. It's a violent release - I don't do it, I back it off a few notches before using the release cams.
At work --everyone-- releases them under full tension, then proclaims "they don't last". Nor will they consider backing off a few notches first. This is because they don't really understand how it works, they have no choice but to destroy them. They seem embarrassed to be told there is a better way to operate ratchet straps and are not willing to listen. Such is life under the love/hate relationship with ratchet straps. Like knots - nobody has time for knots or demonstration of knots (except if you learned knots young).
I've watched a few videos and haven't seen one that explains all the details you need to know, to fully understand them. And some are "wrong" too! Can anybody recommend a really good video that explains EVERYTHING about operating ratchet straps? The guys at work will watch a video, and I want it to be a good one.
