operating on a hot summer day with side panels on?
   / operating on a hot summer day with side panels on? #1
v8only
Mb
1988 John Deere 755
Hey all do you guys keep your side panels on or pull them off to help cool the motor down? the owners manual says nothing about this.
Thanks.
   / operating on a hot summer day with side panels on? #2
Side panels tend to keep out debris that would clog the radiator. Removing side panels should be fine in fairly clean conditions, but I dont think it would help a lot. ... I do wish for a higher capacity radiator.
larry
   / operating on a hot summer day with side panels on? #3
I leave the panels on..if the outside temp gets that hot time to shut down..not just for the tractor either.
   / operating on a hot summer day with side panels on? #4
We leave all panels in place regardless of temperatures.
   / operating on a hot summer day with side panels on? #5
Since V8Only (the OP) has a 755 with a Yanmar engine, I doubt he has any worries about overheating.
I only remove my side panels for maintenance.
   / operating on a hot summer day with side panels on? #6
The only time that my side panels are removed is for maintenance.
no concern i just figured why do some manufactures have side panels and some dont. So I thought there might be a summer and winter mode.
   / operating on a hot summer day with side panels on? #9
I don't know about your little JD but I have a 230hp Versatile that has the side panels. With them on it forces all the hot engine air over top the transmission and out the back. In hot weather I did notice a marked difference in the engine/tranny temp with the panels removed. By removing them it allowed hot air to exit out the sides of the engine which kept the hot air from adding to the cooling load on the hydraulic/tranny oil.
If you want to try it do it. You won't hurt a thing.
   / operating on a hot summer day with side panels on? #10
The first tractor we ever had with side panels was an orchard model to keep stuff out of the belts and hoses, now it seems they all have them; none of our old tractors have them.
2012 CATERPILLAR 279C2 SKID STEER (A51242)
2012 CATERPILLAR...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A55302)
2019 Krause...
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50775)
IF YOU BID ON AN...
MAHINDRA 2810 TRACTOR (A54756)
MAHINDRA 2810...
2016 Godwin CD150M 6in Dri-Prime Pump S/A Trailer (A54811)
2016 Godwin CD150M...
2019 CATERPILLAR 289D3 SKID STEER (A52705)
2019 CATERPILLAR...
