Operating a round bailer and haybine
   / Operating a round bailer and haybine #1
JaredWardall
John Deere 3020
I am wondering if a John Deere 4520 will run a round baler and a haybine. I that will not work will the JD 4720 work? Any information is greatly needed and appreciated. Thanks!
   / Operating a round bailer and haybine #2
What size round baler and Haybine?
A 7 or 9 foot haybine and a average sized round baler. Not huge and not small. Cutting your average hay crop some alfalfa, but mostly grass. Maybey 5 or so acers
   / Operating a round bailer and haybine #4
A 4720 weights according to JD website Approx. Ship Wgt, lb. (kg) Open; Cab Open-3700 (1679); Cab-4345 (1971) and has PTO HP (kW) - Hydrostatic transmission 56.0 (41.8) per SAE so I would say a 4X4 rd baler would be a LOAD. A 4720 should be able to handle a 7 ft Haybine/Mo-Co
   / Operating a round bailer and haybine #5
Jim's giving good advice.
Look at the specs for the JD 4x4 (smallest they make) baler:
Product Specification for 448 Round Baler
HP requirements are important, but there are other factors that determine whether or not your tractor can really "handle" a piece of equipment. For example, pay attention to the weight of the baler. With a full roll of hay inside, the baler will weigh more than your tractor! Not a good situation.
Ok, that makes sense. Thanks for the info!
   / Operating a round bailer and haybine #7
I really chased this question around for 5-6 months before I just acknowledged that it would not be a wise investment to spend $45K (with loader and full hyd options) and have a tractor that was on the "lower edge" horsepower-wise to get the job done.
The better choice - IMO - is to work at the question with a tractor option that has a bit more horsepower than is necessary to get the job done. :thumbsup:
AKfish
   / Operating a round bailer and haybine #8
The haybine is the easy part. You can run one on a Ford 3000. The issue is the baler and I think you would be limited to the Vermer 5400 series or the 4x4 Massey. Check the new NH 4x4 baler for it's hp requirements. The 4510 should be fine. I was running my haybine on the McCormick GX50 which had 42 PTO hp and weighed about the same and had no problems.
40 Yard Roll Off Container Dumpster (A49346)
40 Yard Roll Off...
New/Unused 2025 CFG MX15RX Mini Excavator (A48837)
New/Unused 2025...
2016 FREIGHTLINER CASCADIA SLEEPER TRUCK (A50046)
2016 FREIGHTLINER...
2018 CATERPILLAR 299D2 XHP SKID STEER (A50458)
2018 CATERPILLAR...
66in Light Material Bucket Skid Steer Connection (A50397)
66in Light...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A48081)
2000 Thomas Built...
