Operating a PTO Driven Chipper on a MF Solo
   / Operating a PTO Driven Chipper on a MF Solo #1
1715Ben
Hanover, Penna.
Massey Ferguson 1715 Simplicity Legacy XL
I researched my question on this site and didn't necessary find the resolution in the threads I found. This, I am certain, is a common question. How does one run a chipper driven by a PTO without having to have the seat occupied? I tried a couple didn't ways to engage the PTO this weekend, but each time the tractor shut off as soon as my weight was off the seat. Ultimately I had someone else toss a few limbs in the chipper, but I can't always guarantee having a helper available.
I have a new Wallenstein BX52s and a 1715 combo, which worked like a charm with its brand new knives. It processed 4-5" hemlock limbs with ease (I'd normally burn those in my fire pit, but I needed some wood chips to keep the dogs feet from getting muddy in their outdoor area).
Anyhow, what's the trick to keeping the tractor running while feeding the chipper?
   / Operating a PTO Driven Chipper on a MF Solo #2
Sorry that I haven't run an MF, but on "most" tractors, if you set the parking brake, put it in neutral and engage the PTO before getting off the seat, it will continue to run. Did you try that?
Alternatively, did you read the owners manual. :laughing:
   / Operating a PTO Driven Chipper on a MF Solo #3
*ducks before the safety police arrive* jumper the seat switch.
LOL. I actually planned to read the owner's manual but real life got in the way. I did check online to see if MF had an online manual like many manufacturers do, but couldn't find it. I *think* I set the parking brake, but it was muddy and I may have subconsciously kept my foot on the brake with enough force that it didn't engage the parking brake. I'll try it again with the brake set. Thanks.
Hahaha. That's Plan B.
I don't necessarily object to the safety seat concept. I had an older John Deere (60's vintage) some time ago and it was quite possible to walk up to the tractor with the mower engaged and if someone was not paying attention I could see how they could get an unplanned pedicure or worse.
   / Operating a PTO Driven Chipper on a MF Solo #6
Ben - I've seen this same ? asked on another thread. I don't remember if there was ever a "satisfactory" answer. I think the temporary answer was something like a 40# bag of dog food - in the seat. Manufacturers can't be so completely stupid as to have overlooked this point.
They should all have a system that will allow "normal" operations. I get my tractor set - the chipper( Wally BX92S ) set - slowly engage the PTO and bring it up to speed - stand up - the buzzer will buzz for about ten seconds and that's it. By the time I've dismounted and come around and picked up the first tree - the buzzer has long since quit.
There MUST be some magic combination of button pushes/lever twitches, etc that will shut the buzzer down.
I NEVER use the park break. Too easy to forget and drive off with it still set.
   / Operating a PTO Driven Chipper on a MF Solo #7
A big complaint on the early GC2300 was the seat foam would freeze, not allowing the seat switch to work. Really hard to use a snowblower. Had to jumper it to clear snow, also worked well for the chipper. IMG_8220.JPGIMG_8222.JPG
   / Operating a PTO Driven Chipper on a MF Solo #8
I was surprised several years ago when we got the Puma 125 at the farm, it has the full power shift and shuttle with a parking brake,
not a park position like the older Magnums and it was quite easy to start off with the parking brake engaged with the Puma
and the newer New Holland, both of these what I would consider upper level tractors, but my Branson 8050 with the power shuttle
if the parking brake is applied and the shuttle lever engaged it just sits and beeps at you, comes in handy at times.
As far as the OP I would certainly hope that they provided a way to run the pto without an operator in the seat.
   / Operating a PTO Driven Chipper on a MF Solo #9
Only thing worst than a seat safety switch is back up safety shut offs on garden tractors...!
   / Operating a PTO Driven Chipper on a MF Solo #10
I have not tried this but I bet you could use a ratchet strap to hold down the seat.
Then it would be quick to enable the safety switch when you are done.
2014 PJ TRAILER 40' TANDEM AXLE GOOSENECK (A52472)
2014 PJ TRAILER...
2015 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
2013 INTERNATIONAL SA615 ROUSTABOUT TRUCK(INOPERABLE) (A52472)
2013 INTERNATIONAL...
2022 New Holland T5.120 Tractor with Loader (A51573)
2022 New Holland...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52748)
80in HD Tooth...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2018 Ford F-150...
