Operating a one way cylinder with a two way only rear hydraulic coupler on the kioti
   / Operating a one way cylinder with a two way only rear hydraulic coupler on the kioti #1
RandyT
Elite Member
BEECHER CITY, IL
KIOTI DK45S
Just wondering how you connect the one way cylinders for say a batwing mower to a Kioti tractor that has two way hydraulics only without a float position without deadheading the pump.
   / Operating a one way cylinder with a two way only rear hydraulic coupler on the kioti #2
There is no problem operating a single acting cylinder with the SCVs on a Kioti. Just choose the port to plug into based on if you want the cylinder to extend when you move the lever forwards or backwards. With the lever centered no fluid is flowing out of the ports and there is no deadheading. I operate the single acting lift cylinders on my hay mower using the lower port of one of the SCVs on my DK65 so that it lowers when I move the lever forwards.
Greg
