Operating a dozer on slopes
/ Operating a dozer on slopes #21
Jfall, I dont think a 764 will be good on a cross slope of any steepness. The rubber tracks will wear faster and have problems. I ran a Case articulated rubber track tractor hauling 2 18 yard pans. I had to trim a 3to1 slope with it and a finish pan. After a few passes we had several rubber shavings in the undercarriages. Im dying to try out a 764 when the nearest dealer gets one. Im hoping to get a wheel dozer for the landfill I run this comming year for maintenance work to save walking the D5B.
/ Operating a dozer on slopes #23
I have side cast on a 1:1 frequently and sometimes steeper than that. However, you have to be able to keep your lower track in the flow line with your blade uphill slightly. Generally, you can stay on a 2:1 from the top working your way down... dependent on material type and machine. As far as backing up a slope; that depends on the material and machine too, e.g a D-8 - D-10 can only manage a 2:1 that is cut properly to grade, lowering your rippers helps distribute the weight and will help climb a steeper slope in some situations.
terrasmooth.com
/ Operating a dozer on slopes #25
We were clearing hundreds of miles of right of way for a seismic job. Some big bills on it. We had five dozers running and there was big hill three of them refused to go down because it was too steep. One guy there used to clear pipeline right of ways in Wyoming and he said no problem. He went to the top and pushed down using his blade and rippers to control his ascent. It was impressive to watch. He looped around and went down several times making it smooth but still steep. I don't know the grade but I tried to go up it on a four wheel drive fourwheeler while leaning all the way over the handlebars and it still felt like I was going to flip over backwards and I couldn't go up it. When the dynamite drills got there they had to have the dozer latch on to them and lower them down the hill.
2019 COLEMAN BT200X MINI-BIKE (A64280)
2019 COLEMAN...
New/Unused ATS Welding Machine (A65583)
New/Unused ATS...
2022 EZ-GO ELITE...
2019 Ford F250 4x4 Crew Cab Pickup Truck (A64194)
2019 Ford F250 4x4...
Caterpillar C18 Industrial Diesel Engine - Serial N8F01120 - Power Unit - Pump Takeout (A63689)
Caterpillar C18...
2006 GODWIN GHP45KW-RC 45 KW TOWABLE GENERATOR (A63276)
2006 GODWIN...
