Open vs Closed Center - How to tell
   / Open vs Closed Center - How to tell #1
random2708
Iowa
NH TC33DA
On a New Holland TC33 with rear hydraulics is there a default for whether they are open or closed center? Can they be either way?
It's a silly question I know, but the tractor is new to me and I'm not certain what I have. Getting ready to put a 3 pt log splitter in service and the manual has the big warning about getting it wrong and ruining the splitter.
Thanks in advance.
   / Open vs Closed Center - How to tell #2
You are a lot more likely to do damage to the tractor's hydraulics than the splitter's. But the folks that wrote the splitter manual care more about their splitter than your tractor.
Your TC has open center hydraulics. This is a system design characteristic and as such is not switchable or something that can be altered easily once a tractor leaves the factory. A spool valve, on the other hand, can often be converted from open to closed center and back by installing or removing a plug or sleeve. Be sure the spiltter's valve is set up for open center hydraulics.
Thanks Rick!
   / Open vs Closed Center - How to tell #4
Just to confirm what rick wrote-Your machine is OC.
Thanks Kenny!
2014 Volkswagen Passat TDI SE Sedan (A50324)
2014 Volkswagen...
Grundfos Centrifugal Pump (A50121)
Grundfos...
(1) HD 27ft x 24ft Full Garage Kit Metal Building Frame (A51573)
(1) HD 27ft x 24ft...
2020 CHEVROLET W4500 16FT REEFER BOX TRUCK (A52576)
2020 CHEVROLET...
KJ U-Type Shackles (A50121)
KJ U-Type Shackles...
2018 Bobcat T590 Compact Track Loader Skid Steer (A50322)
2018 Bobcat T590...
