Open or closed hyd. system
/ Open or closed hyd. system #1
2458n
I am considering the purchase of a late 70's White 2-60 tractor it comes with a 1730 front loader. Will I be able to use this with a open-centered 750 arps 3pt. back hoe? What do I need to know?
/ Open or closed hyd. system #2
You could perhaps use a PTO pump with the BH.
J.J. thanks for the reply. I did buy that tractor tonight will pick it up in the morning. The tractor has a hyd pump mounted right above the 540 pto shaft. This is used to power the front loader. The system seems self contained wth a reserve oil tank and filter on the loaders right hand side frame. On the back axle is two hyd quick connects. These appear to be plumbed to the transmission. Everything is clear as mud in my mind. Buyers remorse and excitement of a new project at the same time.
/ Open or closed hyd. system #4
Sounds like you possible have rear remotes. THose could be used to plumb the backhoe.
/ Open or closed hyd. system #5
It don't get any better than that .... :D
UNUSED WOLVERINE RCR-12-84W-84" HYD ROCK RAKE (A64281)
UNUSED WOLVERINE...
2022 Ford Explorer AWD SUV (A61574)
2022 Ford Explorer...
20ft trailer (A61569)
2017 Ford F-550 4x4 Ext. Cab Auto Crane 4004EH 2 Ton Crane Service Truck (A61573)
2017 Ford F-550...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59911)
2016 FREIGHTLINER...
Denyo DCA-600SPK 500kW Sound-Attenuated Diesel Generator (A63689)
Denyo DCA-600SPK...
