Oops - 10W-30 Mixed with Hydraulic Fluid
   / Oops - 10W-30 Mixed with Hydraulic Fluid #1
strez
Southern Tier, NY
New Holland TC30 HST 4WD
Did the 300 hour service on my TC-30 (w/HST) today. After replacing both filters, I went to top off the hydraulic fluid with what I thought was hydraulic fluid.
Oops. I spilled in about 1 cup of 10W-30 before I realized my mistake.
I'm inclined to do nothing, thinking that little bit of motor oil mixed in with 17+ gallons of hydraulic fluid sesms almost insignificant.
Thoughts/opinions?
-Jeff
   / Oops - 10W-30 Mixed with Hydraulic Fluid #2
Thoughts/opinions?
-Jeff
I wouldn't worry about it, but that is just me
   / Oops - 10W-30 Mixed with Hydraulic Fluid #3
i agree that is an insignificant amount mixed in with the hyd fluid
   / Oops - 10W-30 Mixed with Hydraulic Fluid #4
Thoughts/opinions?
-Jeff
I don't think I'd worry about a cup of 10W-30 in the fluid, but I'm pretty sure you don't have 17+ gallons of hydaulic fluid in a TC30. My TC45D only holds around 10 gallons. I'd be shocked to find out a TC30 holds that much fluid. I'd hope you didn't put that much into the reservoir.
You are correct - 8.8 gallons. My mistake - I misread the manual when I posted my original post. Thanks.
   / Oops - 10W-30 Mixed with Hydraulic Fluid #6
As the others have said...Don't worry about it;)
   / Oops - 10W-30 Mixed with Hydraulic Fluid #7
Only 1 cup, I wouldn't worry about it either.
   / Oops - 10W-30 Mixed with Hydraulic Fluid #8
Pour a cup of hydraulic fluid Remover in...that should do the trick.
   / Oops - 10W-30 Mixed with Hydraulic Fluid #9
Thoughts/opinions?
-Jeff
Don't loose any sleep.. I have topepd off hyd systems with 10w30 or 30w oil in a pinch when in a bad situation..... no sleep loss..
soundguy
CAT Skid Steer (A50322)
CAT Skid Steer...
BAUER ATD-750 VERTICAL HYDRAULIC PIPE HANDLER (A53843)
BAUER ATD-750...
2025 AGT ATK-B1000 (A50123)
2025 AGT ATK-B1000...
2025 K1230 UNUSED (10) Wire Mesh Netting Rolls (A53117)
2025 K1230 UNUSED...
2020 Ford Transit 250 Cargo Van (A51692)
2020 Ford Transit...
