Oops - 10W-30 Mixed with Hydraulic Fluid
   / Oops - 10W-30 Mixed with Hydraulic Fluid #1
strez
Southern Tier, NY
New Holland TC30 HST 4WD
Did the 300 hour service on my TC-30 (w/HST) today. After replacing both filters, I went to top off the hydraulic fluid with what I thought was hydraulic fluid.
Oops. I spilled in about 1 cup of 10W-30 before I realized my mistake.
I'm inclined to do nothing, thinking that little bit of motor oil mixed in with 17+ gallons of hydraulic fluid sesms almost insignificant.
Thoughts/opinions?
-Jeff
   / Oops - 10W-30 Mixed with Hydraulic Fluid #2
Thoughts/opinions?
-Jeff
I wouldn't worry about it, but that is just me
   / Oops - 10W-30 Mixed with Hydraulic Fluid #3
i agree that is an insignificant amount mixed in with the hyd fluid
   / Oops - 10W-30 Mixed with Hydraulic Fluid #4
Thoughts/opinions?
-Jeff
I don't think I'd worry about a cup of 10W-30 in the fluid, but I'm pretty sure you don't have 17+ gallons of hydaulic fluid in a TC30. My TC45D only holds around 10 gallons. I'd be shocked to find out a TC30 holds that much fluid. I'd hope you didn't put that much into the reservoir.
You are correct - 8.8 gallons. My mistake - I misread the manual when I posted my original post. Thanks.
   / Oops - 10W-30 Mixed with Hydraulic Fluid #6
As the others have said...Don't worry about it;)
   / Oops - 10W-30 Mixed with Hydraulic Fluid #7
Only 1 cup, I wouldn't worry about it either.
   / Oops - 10W-30 Mixed with Hydraulic Fluid #8
Pour a cup of hydraulic fluid Remover in...that should do the trick.
   / Oops - 10W-30 Mixed with Hydraulic Fluid #9
Thoughts/opinions?
-Jeff
Don't loose any sleep.. I have topepd off hyd systems with 10w30 or 30w oil in a pinch when in a bad situation..... no sleep loss..
soundguy
2018 INTERNATIONAL LT625 (A53843)
2018 INTERNATIONAL...
2006 International 4300 Water Tanker Truck (A52384)
2006 International...
2014 Ford Escape SUV (A51694)
2014 Ford Escape...
2024 JOHN DEERE 35P LOT NUMBER 107 (A53084)
2024 JOHN DEERE...
2007 Utility 3000R 53ft T/A Reefer Trailer (A51692)
2007 Utility 3000R...
2012 RAM 5500 Bucket Truck - Cummins Diesel - Automatic - 4X4 - Versalift SST40 Boom (A53473)
2012 RAM 5500...
